Replace distributor on Crx vtec -90
Old Mar 11, 2010 | 10:02 AM
jim1980's Avatar
TRIAL USER
Icon2 Replace distributor on Crx vtec -90
Hi,
I'm wondering how hard it is to replace a distributor in a CRX vtec -90 ?
How long time does it take ?
Anyone know of a video making this on the internet maybe ?
Is it possible to replace the old distributor with a new one, and skip the timing of the belt ? If i make marks where my old distributor is and I also make sure the "rotor" is on the same place, Do you think it would be possible to make a good working engine that way ?
I hope you understand what I mean , and sorry for my poor English !
//Thanks in advance
Old Mar 11, 2010 | 10:31 AM
crx_si-r's Avatar
Default Re: Replace distributor on Crx vtec -90
Unbolt 3 bolts, remove distributor cap. Before removing the distributor draw a line showing it's placement.
Try and be as accurate ad possible and draw the line in the same place on the new distributor. And install it. And put the cap back on.
That's it.
Old Mar 11, 2010 | 12:06 PM
DCRB's Avatar
for best performance you should still reset the ignition timing. replacing the dizzy does not involve messing with the timing belt unless it is bad or had jumped a tooth
taguchi09
Jun 11, 2011 04:52 PM
96a-ccord
Feb 26, 2010 02:04 PM
jdmkidd23
11
Nov 17, 2008 08:54 AM
djcaseanova
Sep 23, 2003 09:38 PM
LB CRX
Jul 24, 2002 08:14 AM
