TPS has low output voltage! Help!
Old Mar 9, 2010 | 08:32 AM
SsSteven's Avatar
Default TPS has low output voltage! Help!
I just picked up a 93 gsr, still gots the og b17, I got a cel for the throttle position sensor (7 blinks using the jumper) I measured the middle feedback wire when trying to calibrate the sensor mounting position, I only get 0.011-0.033vdc mounted all the way to the right, aren't I supposed to get .50vdc?
When I try measuring at wot, I only get 1.1vdc.
I checked my input voltage 4.25 and ground is good. I also tried a used (supposed to be a good known sensor) same results.
Could I have two bad sensors? Is my ecu bad? Maybe a short somewhere?
Please help gurus of Honda motors!
Old Mar 9, 2010 | 04:03 PM
SsSteven's Avatar
Default Re: TPS has low output voltage! Help!
fixed it, just unbolted the ECU and did pin to pin (ohms) looked good, then measured voltage at TPS again and BAM! 0.58, adjusted to .50, NO MO CEL! BOIII!!
Must of been a bad connection at the ECU, i did notice that whoever owned the car before did a shitty stereo wiring job, Wires everywhere, damn spaghetti.
Old Mar 11, 2010 | 05:43 PM
SsSteven's Avatar
ok CEL came back after driving over 50mph, I checked the codes and it blinks 7 fast (TPS) 1 slow blink, 2 medium blinks and 3 fast. Is that a knock sensor code?
Any help would be greatly appreciated.
Old Mar 13, 2010 | 05:43 PM
SsSteven's Avatar
ok, now I'm only getting the 7 blinks, TPS again? But it only comes on after I go 50mph or after vtec goes on.
BTW, no mods all stock.
Any input would help greatly.
Thanks in advance.
Old Mar 14, 2010 | 07:00 PM
SsSteven's Avatar
please help out a newbie
Old Mar 15, 2010 | 10:34 AM
SpeedRacerEX-R's Avatar
http://www.rockauto.com/catalog/rafr...398551k1990382
Old Mar 15, 2010 | 11:03 AM
SsSteven's Avatar
I had already swapped out TPS sensors, I see .50 volts when the ignition is on and 4.50vdc when WOT. Still getting the 7 blinks....
Old Mar 15, 2010 | 11:10 AM
day1's Avatar
What are you getting for your 5v reference? look near your ecu again finger through the wires and look for a break
is the car still driving normal?
Old Mar 15, 2010 | 05:36 PM
SsSteven's Avatar
I get 4.50v at the reference, I correctly calibrated the TPS to .50vdc.
Yes the car still drives normal, vtec still kicks in and all. The CEL is just annoying. Could my alternator be bad?
ZombiePharoh
Dec 3, 2012 02:45 PM
1fstlude
Dec 10, 2011 06:24 AM
luispequeno
Dec 13, 2010 09:16 AM
lmike6453
Oct 29, 2009 06:02 PM
Lowez
May 30, 2002 07:06 PM
