How to change a timing belt
Old Mar 7, 2010 | 07:51 PM
tacchan's Avatar
Default How to change a timing belt
I just picked up a car with 213 000Kms and I have no idea if the timing belt has been changed, so I am thinking of changing it myself.
How hard is it to change it and how long will it take? Should I change the water pump too? Do I need a timing gun? Where should I get the parts for it from? Honda or is aftermarket ok?
What else needs to be changed and attended to when the timing belt is changed?
I am downloading a helms manual and hopefully it gives me the full instructions on how to change it, however I would appreciate any input that you guys have on this.
Thank you.
Old Mar 8, 2010 | 05:19 AM
Matt93eg's Avatar
Default Re: How to change a timing belt
Gotta love how people come on here and ask for help but give no information what so ever about the engine there talking about and what car it is in.
Just go out and buy yourself a manual for the the engine you have and follow it. And just for the record, no you will not need a timing light to set Mechanical Cam timing, a timing light is to set the Ignition timing.
Old Mar 8, 2010 | 07:27 AM
devney's Avatar
Get an OEM timing belt, water pump, and tensioner from Honda. Then read that helms manual.
Old Mar 8, 2010 | 09:21 AM
tacchan's Avatar
Sorry, its a 2000 Civic Hatchback DX SE with I believe a D16Y7 engine.
What does the tensioner do? Does it need to be set/adjusted or does it automatically tension the belt?
Old Mar 8, 2010 | 09:27 AM
Matt93eg's Avatar
You use the Tensioner to put Tension on the belt once you have it installed. It won't self adjust because there is a 14mm bolt in the center of the pulley and once it tightened down the tensioner stays in place. Belts usually will not stretch like chains do. A service manual will explain how you set the tension so I am not going to explain it.
Old Mar 8, 2010 | 09:49 AM
tacchan's Avatar
I just read the manual and it says to change the timing belt every 168 000kms. So I guess I will wait until 300 000 to change it. By that time I should have enough money for an engine swap hopefully.
Old Mar 8, 2010 | 09:52 AM
Fresh'86's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-complete-diy-how-timing-belt-water-pump-change-d16z6-lots-pics-649277/
The HELMs manual I have gives the most useless information on how to adjust timing tention.
Old Mar 8, 2010 | 09:56 AM
Fresh'86's Avatar
I also found this super helpful:
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Mar 8, 2010 | 09:57 AM
Jockone's Avatar
If the belt has not been changed before and you wait you could be heading for disaster if the belt breaks you will bend valves.
Jockone's Avatar
Old Mar 8, 2010 | 09:59 AM
Fresh'86's Avatar
Dude, 168,000kms is 105,000miles. Check your conversions. It's NOT 1.78 mile = 1kms
The correct conversion is:
1 Mile = 1.6kms
Old Mar 8, 2010 | 10:06 AM
tacchan's Avatar
Thanks for all your help and input. I really appreciate it.
Old Mar 8, 2010 | 11:25 AM
Kevins89notch's Avatar
Originally Posted by Fresh'86
Great link, thanks.
Old Mar 8, 2010 | 11:31 AM
sde780's Avatar
No you don't need a timing gun, don't mess with the distributor at all
Old Mar 8, 2010 | 11:39 AM
Matt93eg's Avatar
I wouldn't use the word "will". I have seen and replaced T-Belts on several D16Z6 engines, two SOHC Accord engines and they had not bent any valves from the broken T-Belt. Doesn't mean you won't bend valves but I don't think saying you "will" bend valves is appropriate. However, I am not recommending anyone run past the service interval which will eventually lead to a broken T-Belt, the belt should be replaced when due so that you don't ever have to deal with a broken T-Belt.
Old Mar 8, 2010 | 11:49 AM
BryanM.'s Avatar
Resident Gearhead
https://honda-tech.com/forums/showthread.php?t=649277
Ironically, that thread gives ZERO information about adjusting pulley tension lol.
Old Mar 11, 2010 | 08:30 PM
tacchan's Avatar
1 Mile = 1.6kms
Dude, the Helms manual said change the timing belt every 105 000miles or 168 000 kms.
Atauto
Honda CR-V & Element
10
Apr 25, 2015 07:53 PM
ezol
Acura TL, RL & ZDX
11
Sep 21, 2010 08:29 AM
bart2546
Dec 31, 2006 06:30 AM
bart2546
13
Dec 30, 2006 10:51 AM
hatchydude
Jul 17, 2005 04:49 PM
