valve ajustment
Old Mar 7, 2010 | 04:51 PM
slimm82's Avatar
Default valve ajustment
could improper valve adjustments cause a hella rough idle on a d15b w/ a z6 head?
the setup:
98 civic
jdm d15b (obd2)
z6 head
obd1 dizzy
Old Mar 7, 2010 | 05:11 PM
talkerty's Avatar
Default Re: valve ajustment
Doubt it
Old Mar 7, 2010 | 05:56 PM
newtron63h's Avatar
completely possible.......especially if some valves are more out of adjustment than others......causing the airflow to vary both in volume and velocity. if they were all out of adjustment or all the intakes or all the exhaust valves are out of adjustment then id say this would be less likely. its a simple enough process...........might as well check to be sure.
Old Mar 7, 2010 | 06:16 PM
slimm82's Avatar
thanx homie. this is really pissing me off!!! its my fault tho. i checked everything...EVERYTHING...except the valves. simple enough. ill do it in the morning.
Old Mar 7, 2010 | 06:45 PM
Vindicator9000's Avatar
318 Curves, 11 miles
I agree.
What do you mean by you checked everything? In my experience, the most common causes on Civics are air in the coolant and dirty throttle bodies.
Old Mar 7, 2010 | 07:00 PM
RavingMadman's Avatar
Valve adjustment can make or break an engine.
Check your timing while you're at it, that could cause it as well.
Old Mar 7, 2010 | 10:02 PM
darkenedsol's Avatar
As for checking the valves-it's worth it just to make sure...just make sure the engine is cold. Good luck!
Old Mar 9, 2010 | 07:51 AM
slimm82's Avatar
when i say everything, im refering to timing, wires, plugs, tb, etc. like i said everything. regardless, it was the valves. my car is running beautifully now. for those that offered advise and useful input, thank you.
Darrell Woods
Feb 1, 2021 05:20 AM
lazyxmofo
May 23, 2012 07:04 PM
aragorn1023
Apr 20, 2010 03:56 PM
.RJ
10
Apr 10, 2006 11:19 AM
Timmay
Aug 31, 2003 09:17 PM
