VTEC Engagement Questions
Old Mar 7, 2010 | 09:13 AM
letam06's Avatar
Icon2 VTEC Engagement Questions
Alright. I have a B16a with i/h/e and currently have 2 ecus. I have a chipped P28 ecu that was chipped by speed innovations for a b16a with exhaust and air intake only. The vtec engagement on the P28 is set at 4500 rpms. I also have a JDM P30 ecu which i believe vtec engagement is at 5500rpms. I was wondering which ecu is should use? It also seems like vtec engagment at that low of an rpm wouldnt be to good on the motor. But I don't know to much about ecus. I also have a very slight ticking coming from the head. I have re-adjusted the valves to spec of .006 in. intake and .007 in. exhaust. This made it sound better but it still is there. Could this low vtec engagment cause this or make it worse? thanks for your help.
Old Mar 7, 2010 | 09:17 AM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: VTEC Engagement Questions
P28 is a d16 ecu, unless it is chipped, it is completely wrong for that motor.
Old Mar 7, 2010 | 09:29 AM
letam06's Avatar
If you were to read my post it says that it IS chipped for a B16a.
Old Mar 7, 2010 | 10:07 AM
Top Ramen's Avatar
Stock is 5800, right? If you have not cammed or ported it, moving it too much will only hurt your power. Use the P30.
Old Mar 7, 2010 | 10:11 AM
letam06's Avatar
alright, i was thinking the same thing. not cammed or ported. Just i/h/e for now. Stock valvetrain, stock head, stock cams. Thanks alot!
baulum
Engine Management and Tuning
Feb 16, 2020 08:48 PM
chope045
Jul 15, 2011 11:20 AM
mpls
Feb 2, 2009 01:31 PM
crohnman6
Jan 3, 2006 05:36 PM
808State
Jun 21, 2005 08:08 AM
