Ek Passanger side trans mount help
Old Mar 5, 2010 | 07:00 PM
s14swap240sx's Avatar
TRIAL USER
Default Ek Passanger side trans mount help
I have purchased a civic with a hacked up motor swap. Its a 98 ek coupe. So i am doing an ls swap with gsr trans for a little extra dd power.
The tab on the passanger side framerail (where the trans mounts bolts to)is missing. the trans mount is currently welded to the frame, it looks like crap! What is the best way to fix this when i swap the ls motor in? my car was an auto, one of the previous owners did the manual swap.
is there a better bracket i can use? such as the bracket on an integra or something?!
Old Mar 5, 2010 | 07:10 PM
drifter187's Avatar
Default Re: Ek Passanger side trans mount help
Yes for sure. Use the trans bracket off a new 6.0 GTO, and weld that **** in there.
Old Mar 6, 2010 | 06:18 AM
TRIAL USER
wow. Its a legit question.. you can use the engine bracket on the driver side from the integra because its stronger when you do b swaps into ek's.. mabye there was a chance of using the passanger trans mount. ive search, not much to be found in relation to my specific question.
Freedo_Civegra
May 10, 2018 09:43 AM
Hondaruss
16
Oct 14, 2010 04:28 PM
R666_EK
Mar 11, 2009 02:34 PM
MrPotatoeHead
Nov 21, 2007 08:41 PM
redEH2
Sep 5, 2005 01:49 PM
