Will this dp fit both these turbos?
Old Sep 7, 2002 | 06:39 PM
blufke's Avatar
Default Will this dp fit both these turbos?
i was wondering this, if i have a drag/maxrev/revhard mani. and i have my volvo t3 on it and a downpipe that works. will that same downpipe fit something like a t3/to4e? im thinking it wont because its a t4, but am i wrong?
also, if im running that volvo turbo on one of those manifolds what is a good way to seal the place where the external wg goes, allowing the external wg to be used when i upgrade to the bigger turbo.
oh, and one more Q , if i have all my piping setup with the volvo turbo and then get the bigger turbo, what probs will i have with the ic piping?
Old Sep 8, 2002 | 01:28 AM
blufke's Avatar
Default Re: Will this dp fit both these turbos? (blufke)
somebody?
Old Sep 8, 2002 | 04:28 AM
rjardy's Avatar
They share the same downpipe. allthough its a t4 compressor housing the t3 downpipe should work.
i think, anyine else?
Rob
Old Sep 8, 2002 | 04:59 AM
sutrusu's Avatar
Default Re: Will this dp fit both these turbos? (rjardy)
they probably (actually, they do) have different bolt patterns. my t3 has a wierd *** exhaust bolt pattern, and now i have to get a flange made and cut the downpipe i just bought
Old Sep 8, 2002 | 05:15 AM
rjardy's Avatar
Default Re: Will this dp fit both these turbos? (sutrusu)
some t3 so ahve different bolt patters, the older t3's usually have 4 bolts and the newer one have 5 bolts.
Rob
Old Sep 8, 2002 | 05:18 AM
sutrusu's Avatar
mine has 7
Old Sep 8, 2002 | 05:27 AM
rjardy's Avatar
mine has 7
its a t3? garett?
Rob
Old Sep 9, 2002 | 02:26 AM
blufke's Avatar
anyone know? its off an 87-89 volvo 740 turbo with intercooler. will the two turbos bolt up to say a maxrev bseries manifold and be able to use the same dp? and what is a good way to block off the wastegate port until one is used with the next turbo?
Old Sep 9, 2002 | 02:55 AM
rjardy's Avatar
how many bolts are on the stock downpipe?
Rob
Old Sep 9, 2002 | 04:25 AM
blufke's Avatar
i dunno. dont have any of the stuff. thats why im asking.
Old Sep 9, 2002 | 12:39 PM
blufke's Avatar
any turbo gurus have any input?
Solomon1468
Mar 16, 2010 10:47 PM
kccord
Jan 2, 2010 12:26 PM
biada1
Nov 28, 2006 12:53 PM
builtB20turbo
Apr 5, 2004 11:13 AM
pip9
Feb 21, 2004 03:49 PM
