How I made a turbo adapter plate
Old Sep 7, 2002 | 12:29 PM
jdblack1's Avatar
Default How I made a turbo adapter plate
I made this adapter plate to fit an IHI 3 bolt flange turbo to a HF manifold. The peice used started as a .5" thick by 5x12 cold rolled steel.
I started by drilling the 4 holes for the HF manifold.
I tapped those holes and installed studs
I did the same on the oppisite side but for the 3 bolt turbo.
The hole in the center is how I centered both of them up.
I then milled 90% of the steel from the center. I used the HF mani. gasket to get a general idea of where it fits. It needs to be portmatched now
here's looking into the turbo from the manifold side
here's the turbo side with the turbine on
Here it is all most finished. the plate needs to be cut down some so the compressor can rotate up.
I did this for a guy that bought this turbo. Adapter plate and turbo cost him 85 bucks. not bad for the ghetto turbo junkie
I hope this helps some people boost on a budget.
This took about 2hrs
[Modified by jdblack1, 1:33 PM 9/7/2002]
Old Sep 7, 2002 | 03:31 PM
Honda4CX-T's Avatar
Default Re: How I made a turbo adapter plate (jdblack1)
I like making custom stuff out of nothing also .....
Good job .....
Old Sep 7, 2002 | 11:57 PM
accordfreak's Avatar
Default Re: How I made a turbo adapter plate (Honda4CX-R)
looks good! where do u get the plate from?
Old Sep 8, 2002 | 04:09 AM
jdblack1's Avatar
Default Re: How I made a turbo adapter plate (accordfreak)
It was just a peice we had laying around at the shop
Old Sep 8, 2002 | 07:10 AM
Hybrid's Avatar
I like to think custom more so than getto.
But some times with the stupid problems you have with custom set ups then they can be called getto.
But for the price I spent on my custom 14b turbo setup, a kit can't touch it!
wildcard69
Jan 5, 2005 03:42 PM
sinfulj32
Nov 14, 2004 06:53 AM
kHoA DoGG
Nov 30, 2003 11:11 PM
It's*BOLO!!
May 20, 2003 03:34 PM
beedoublejay
Dec 20, 2002 09:30 AM
