Huh? Does a faulty vss sensor/speedometer reading affect vtec not engaging?
Old Feb 25, 2010 | 02:50 PM
kaboom954's Avatar
Default Huh? Does a faulty vss sensor/speedometer reading affect vtec not engaging?
I recently bought a 93 del Sol Si. Sweet little car and I've been fixing it up pretty nicely. Anyways the speedometer is not working, but everything else such as the RPM gauge is reading correctly and I have no CEL's. I've been thinking most likely the VSS sensor is shot and I need a new one since my crap wont read past 20 MPH.
Anyways I came across an old thread and someone stated that if the VSS sensor isn't reading correctly then VTEC will not engage. How is that so? I thought VTEC depended upon the RPM's in order to function. If my cluster is reading RPM's correctly than shouldn't VTEC engage correctly?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/question-about-d16z6-speed-sensor-2357142/
Old Feb 25, 2010 | 03:00 PM
1993-eg1's Avatar
Default Re: Huh? Does a faulty vss sensor/speedometer reading affect vtec not engaging?
the ecu looks for alot of things before letting vtec engage like engine temp oil pressure and yes i was told speed i am not to shore on y speed is part of the equation
Old Feb 25, 2010 | 03:01 PM
delsolproblems's Avatar
The Vtec system needs the VSS signal to engage. This is to keep Vtec from enaging when revving in neutral.
Vtec needs:
Oil pressure
Engine speed signal (RPM)
Vehicle speed signal (MPH)
TPS signal
MAP sensor signal
Coolant temp signal
Old Feb 25, 2010 | 03:23 PM
kaboom954's Avatar
Oh crap well thanks for the answers guys.
I hardly ever rev past 4800k to even engage VTEC but this morning on the way to work I was having a little fun with a co-worker and I had a feeling this pos D16Z6 was lacking in power. Well thanks "VTAK" for screwing me over
stehigs321
15
Mar 1, 2019 05:16 PM
young geezer
May 21, 2009 06:20 PM
ricearoni56
Feb 8, 2008 09:31 AM
HONDRETTI
Nov 20, 2007 10:20 AM
civicseth
16
May 18, 2005 08:51 PM
