Idle
Old Feb 23, 2010 | 08:34 AM
Red-Rag-B18's Avatar
Default Idle
I drive an integra ls 98, just wondering where is the idle controller, i recently put on a intake and when iturn on my car its shutting off due to the idle being so slow, so where is it on the manifold?
Old Feb 23, 2010 | 08:39 AM
SoTexDC2's Avatar
Default Re: Idle
The ECU should control the idle automatically. Try cleaning the IACV (Idle Air Control Valve)
Did you have this problem before you installed an intake?
Throwing any CEL's?
Old Feb 23, 2010 | 08:45 AM
Default Re: Idle
no it didn't, i just think that yeah either i need to clean the IACV or open the throttle bodies a little more but i dont seem to know where it is on the manifold
Old Feb 23, 2010 | 08:52 AM
SoTexDC2's Avatar
Default Re: Idle
You can use the throttle cable bracket and adjustment nut to keep the throttle plate open slightly if you need to, but this shouldn't be a permanent solution.
I don't recommend doing that at all, honestly. The IACV should automatically let the proper amount of air in to maintain idle. It may be stuck. It's only two bolts, pull it off and clean it.
Lethal001
25
Jun 16, 2008 04:49 PM
NAmodified
Feb 1, 2007 11:46 AM
SOHCmaster
Mar 2, 2005 03:42 PM
94SHOWLS
Feb 17, 2005 12:31 PM
Lowtightcivic
Feb 1, 2004 01:38 PM
