99-00 how to check my fuel pump is working or not
Old Feb 23, 2010 | 01:46 AM
zoopreme's Avatar
Default 99-00 how to check my fuel pump is working or not
ask title stated what line to i pull out to check if its wokring my car crank but dont turn over
Old Feb 23, 2010 | 02:01 AM
v8killaaaa's Avatar
Default Re: 99-00 how to check my fuel pump is working or not
Crack that 17mm loose, but watch your eyes just in case you are getting proper fuel pressure.
If no fuel when 17mm is relieved, try to cycle the ingition to the "on" position with the 17mm loose. If you get out and see fuel your pump is working, from there you need a Fuel Pressure gauge to check if you are getting the proper amount of fuel.
Old Feb 23, 2010 | 09:01 AM
sleepinDA's Avatar
check for spark first .... more than likely distributor ..... its not a gm ....lol
Old Feb 23, 2010 | 11:15 AM
MRMOCOS's Avatar
Turn the key to II and have someone listen to the pump to see if it primes. If not dont bother with the fuel filter.
dylaxiin
May 9, 2011 07:28 PM
happyabortion
Dec 22, 2009 07:59 AM
tegturbo
Aug 11, 2005 04:18 PM
ronqqq
May 30, 2005 09:39 AM
Boostless97Lude
Dec 26, 2002 11:33 AM
