WTF VTEC
hi guys. seriously about to drive this car off a cliff. 96 accord converted to obd1 and vtec (doesnt fking work) ive added wires to a4 and d6. i unwrapped the engine harness and grounded the pressure switch to that battery even.. still getting fking code 22. what am i doing wrong? thanks in advanced for your responses. i appreciate the help
And gone through this?
http://www.accordinglydone.com/forum...ad.php?t=10214
What's happening when you go to VTEC? Does it peg out and crap on you? Or does it continue to go but throw a CEL or what?
recheck your wiring
then check here
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
then check here
idk cause when this motor was in my coupe i could totally tell vtec was engaged i mean baaaa and baaawwwaaaaaaaaaaaaaaaahhhh are way different./.. the cel just comes on after about a minute of running so idk wtf is the deal.
Have you not flashed the CEL code yet to see what the problem is? I bet that tells you exactly what to fix......
Remember, the thermostat B connector also has a green connector just like the VTEC Pressure switch and so you can mix them up good. I did that on my H22 swap and three days later found out that it was backward and finally VTEC worked.
honestly just cut another harness same plug ran the wires for the pressure switch and its still throwing code 22. vtec pressure switch.. i changed it with another one. im still getting a code. the wires arent loose.. i grounded it to the battery. thats definatley a ground.. wth is going on with this??? everything worked fine until i swapped from the coupe to the sedan.
i swapped it into this sedan because i have a jdm f22b DOHC that im boosting.. so i want this sedan to run right either way. i dont need it since i have a del sol too but that gets lame to drive.yes i changed the switch... but it definitely isn't clogged cause oil leaked out.. and it worked before i pulled it.. so really i have no idea. ill try unclogging it but any other suggestions?
flat-blk-HB
16
Sep 30, 2002 07:04 PM
