Extended Wheel Studs
Old Sep 5, 2002 | 02:47 PM
MugenGTR's Avatar
Default Extended Wheel Studs
i'm thinking about getting some, probably the arp since i heard skunk2 sux. i dont need them but i jus thought it might be nice to have. and i can run slick one of these days. jus curious as to one thing. how do u install them? probably sounds stupid to all u specialists in here but i have no idea how in the world to install them.
Old Sep 5, 2002 | 03:00 PM
Chris83179's Avatar
Default Re: Extended Wheel Studs (MugenGTR)
I have the Skunk2 studs...
I have heard of people saying they suck and they break and yadda yadda, but i found all that out after I had got them. I have had no problems with them, but I am also not putting extreme stress on them as my SOHC motor is such a screamer
The ARP ones i avoided cuz i heard of having to drill the rotor holes bigger and I didn't wanna deal with all that. I took my front knuckles off and rear trailing arms off and dropped them off at the auto shop. The studs have to be pressed on. The shop charged me $80 to press on and tach weld all 16 studs...
Make sure the auto shop doesn't mess up the front wheel bearings during the press work. Those bearings are not cheap
[Modified by Chris83179, 12:02 AM 9/6/2002]
Old Sep 5, 2002 | 03:38 PM
non-VTEC's Avatar
whats the reasoning behind getting extended wheels studs?
just curious
Old Sep 5, 2002 | 05:27 PM
Chris83179's Avatar
Default Re: Extended Wheel Studs (non-VTEC)
just curious
You need them to run drag slicks. the rims are so thick that u need longer studs to have adequate space for the lug to hold on to
Old Sep 6, 2002 | 04:51 AM
RevinRex's Avatar
Default Re: Extended Wheel Studs (Chris83179)
So how much longer are the Skunk2 wheel studs compared to stock? I'm also planning on getting some this winter! Thanks!
Old Sep 6, 2002 | 07:45 AM
Chris83179's Avatar
Default Re: Extended Wheel Studs (YBLegal)
well, i am not sure, but i could measure them i guess if you REALLY want me to...
since my car is on jack stands with no wheels, it wouldn't be too hard...
Old Sep 6, 2002 | 10:06 AM
Wide Open Throttle's Avatar
if i were to get wheel studs i'd get the ones ARP makes.
Old Sep 6, 2002 | 10:16 AM
Gennady's Avatar
New User
https://honda-tech.com/zerothread?id=201846
Old Sep 6, 2002 | 10:18 AM
rastropovitch
Guest
Posts: n/a
I use the Smelly ones on my GSer... I love them. One very important thing is that you must remember to Die cutter them before trying to put the aluminum/magnesium nuts on. With the coating that skunk uses, it makes them very slighty over sized. Plus you need a press for the front'sto seperate the wheel bearing out of the hub
Peace
Schu
Old Sep 6, 2002 | 10:23 AM
Katman's Avatar
..The ARP ones i avoided cuz i heard of having to drill the rotor holes bigger and I didn't wanna deal with all that.
Not true.
I had ARP studs installed on some EG knuckles a little while ago. The splines on ARP studs ARE definitely bigger than the stock splines and don't fit perfectly in the hub all the way; The studs just need to be pounded into the hub with a little more muscle, and they'll fit perfectly in the hub.
The ARP studs are about the length of 2 stock studs stacked on top of each other.
Old Sep 6, 2002 | 10:45 AM
Chris83179's Avatar
Default Re: Extended Wheel Studs (Katman)
Not true.
Cooh, thanx for the info Katman...
Old Sep 6, 2002 | 11:33 AM
Katman's Avatar
np
Old Sep 6, 2002 | 11:42 AM
highbrid's Avatar
ive had the skunk2's for months now and have changed out the tires for slicks many times and have had not a single problem with them. i just put a little moly lube on the studs before putting the bolts on and they go on and off without a problem. They seem to be holding up strong
Old Sep 6, 2002 | 01:00 PM
Chris83179's Avatar
Default Re: Extended Wheel Studs (highbrid)
the only thing with my studs is that they were once gold in color, as they are now silver... I like to switch rims alot...
[Modified by Chris83179, 10:00 PM 9/6/2002]
Old Sep 6, 2002 | 03:20 PM
Steve91's Avatar
You can save some money by going to an autoparts store and buying Dorman 610-323 the are M12x1.5x54mm. Most autoparts stores sell Dorman wheels studs. This part is for a GM car that uses the same dimension and thread patter as the Honda stud, but its about 1/2 to 3/4 inch longer than stock. I think they cost about $1 each.
Old Sep 6, 2002 | 05:04 PM
Jared's Avatar
Default Re: Extended Wheel Studs (Steve91)
I'm using the ARPs now and they just require the persuasion of my 1/2" impact to put the bigger knurl into the honda hub. However, I did have the skunk2s, which are terribly over priced, and I had two strip out in the hub(the knurl stripped, not the hub) and I had to chop them out. Not very pleasant.
Old Sep 6, 2002 | 05:25 PM
Default Re: Extended Wheel Studs (Jared)
i've had wheel studs sieze up on me during and after track events. i wouldn't trust anything other than ARP.
Old Sep 6, 2002 | 05:29 PM
Jared's Avatar
Default Re: Extended Wheel Studs (Wide Open Throttle)
I agree 100%
Old Sep 6, 2002 | 05:44 PM
sparkz's Avatar
The skunk2 studs work fine, just as long as you rethread them. They'll still work if you don't but you'll have a hard time lugging and unlugging your lugs. Only bad thing I can see about them is that they are pricey. Also tack weld any extended lugs you get as well
Old Sep 6, 2002 | 08:20 PM
civbeater90's Avatar
Default Re: Extended Wheel Studs (sparkz)
i like my arp's also.
Old Sep 11, 2002 | 07:13 AM
rex_boy's Avatar
Default Re: Extended Wheel Studs (civbeater90)
I going to put some exteneded studs on too, last track event I put two wheels off and a couple laps latter, I noticed some vibration but didn't know what it was. I pulled into the pits thinking I had a flat. I checked and no flat, but three of the four lugs were loose. I figure any extra length of the studs would give you that much more time before the nuts unthreaded all the way off. scarry situation.
Old Sep 11, 2002 | 07:17 AM
BROOD's Avatar
Default Re: Extended Wheel Studs (rex_boy)
ARP is the way to go
Old Sep 11, 2002 | 08:50 AM
skunked's Avatar
Default Re: Extended Wheel Studs (SLPR)
ARP
Old Sep 11, 2002 | 09:21 AM
martini's Avatar
Default Re: Extended Wheel Studs (skunked)
I use H&Rs on the CRX.
Haven't had a chance to actually run them, but they are on there none the less.
Old Sep 11, 2002 | 11:10 AM
rex_boy's Avatar
Default Re: Extended Wheel Studs (martini)
Yes, I can drive to summitracing which sells the ARP no need to pay shipping.
If they are strong enough for a Corvette they should be strong enough for my CRX.
jimmhatch
32
Feb 11, 2007 12:37 AM
SpoolnG2
Oct 28, 2003 11:40 AM
b19coupe
Aug 19, 2003 11:41 PM
Jared
Aug 13, 2002 02:10 AM
xJ.SLOTHx
Jan 22, 2002 11:03 AM
