SKUNK2 or ARP extended wheel studs?
Old Aug 12, 2003 | 06:24 PM
SpoolnG2's Avatar
Default SKUNK2 or ARP extended wheel studs?
which one do u guys use? and which are better?
Old Aug 12, 2003 | 06:37 PM
DC2's Avatar
DC2
Default Re: SKUNK2 or ARP extended wheel studs? (SpoolnG2)
Can't go wrong with ARP
Old Aug 12, 2003 | 06:39 PM
Foozball26's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (DC2)
Im digging ARP too, They've been in this type of business for quite some time.
Old Aug 12, 2003 | 08:31 PM
integra_gsr98's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (Foozball26)
We've had nothing but bad luck w/ the skunk2 studs. Their own lugnuts do not even thread onto them. We called and called and called and they would not replace them either.
Definately a to ARP.
Old Aug 12, 2003 | 08:34 PM
meanteg's Avatar
New User
Default Re: SKUNK2 or ARP extended wheel studs? (integra_gsr98)
I didn't know ARP had a stud kit for imports.
Old Aug 12, 2003 | 08:37 PM
RenoRacing's Avatar
where's the cheapest place to get these from? also need some lugnuts to go with them.
Old Aug 12, 2003 | 08:41 PM
SpoolnG2's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (HavokRacing)
thanks guys...ARP it is
Old Aug 12, 2003 | 08:52 PM
Driveshaft shop has the ARP part number listed on their website. I am guessing you can get them from summit. As far as lugnuts go, I would recommend the skunk2s. They thread onto every wheelstud other than their own just fine. They are very very light.
Old Aug 13, 2003 | 04:33 AM
BROOD's Avatar
ARPs is the way to go considering the choices. I used the Corvette extended lugstuds and "force" pressed them into my oem hubs. Works good.
I believe I have seen a set of Honda/Acura specific lugstuds from ARP recently, or at least they are soon to introduce them.
**below, possibly so. I guess I never saw that those were available, I wish I would have though. Using the Corvette/Camero studs enlarges the stud holes in the oen hub. So going back to stock Honda sized studs would not be possible with out getting new hubs.**
Modified by SLPR at 8:56 AM 8/13/2003
Old Aug 13, 2003 | 06:32 AM
93LSivic's Avatar
FYI I believe its a domestic Camaro replacement stud that will fit our cars as well. Screw paying that much for ARP's or skunks when these studs are like a $1 each.
*EDIT
Oops, didnt see the post above mine.
Old Aug 13, 2003 | 07:27 AM
Marauder's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (93LSivic)
Heck.....ARP was making studs and bolts for Honda's ChampCar engine years ago!
Old Aug 13, 2003 | 08:46 AM
rolow's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (Marauder)
EF8_FAN Has the Honda ones for sale https://honda-tech.com/zero...28577
Old Aug 13, 2003 | 12:00 PM
PhantomEG's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (rolow)
i havent had any problems with the skunk2 studs and lugs.....
Kinda tight when putting them on but they werk.
Old Aug 13, 2003 | 03:04 PM
Lei Siew Long's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">We've had nothing but bad luck w/ the skunk2 studs. Their own lugnuts do not even thread onto them. We called and called and called and they would not replace them either.
i had two sets of Skunks for my front wheels and 5/8 studs stripped from the hub and spun loosely with the lug still attached. and what integra_gsr98 is correct, their own lugs won't fit on their own studs
Old Aug 13, 2003 | 05:35 PM
JSJ EG6's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (Hatch4urSnatch)
arp studs
my friend skunk2 studs striped
Old Aug 13, 2003 | 06:10 PM
SPOON_BeIgHtEeNsEe's Avatar
Default Re: SKUNK2 or ARP extended wheel studs? (TEAM JSJ)
skunk2 studs SUCK!!!!!!!!
Old Aug 16, 2003 | 10:59 AM
Full-Race Henry's Avatar
I have never had any problems at all with the arp's. But everyone I know has always had problems with the skunk2's
Old Aug 16, 2003 | 11:50 AM
RuthlessEF-9's Avatar
yeah arp is the bomb i wouldn't go with skunk 2 however don't hate on them so much cause their other products are two thumbs up
Old Aug 16, 2003 | 01:26 PM
Darin D.'s Avatar
Default Re: (D16z6turbs)
i have the skunk2 studs. after a few of them started spinning in the hub i got sick of it and welded all of them in.
Old Oct 28, 2003 | 11:40 AM
Reza.dc's Avatar
Default Re: (Willis)
my skunk studs just stripped, gg skunkworks
phaiwezzie
Feb 9, 2011 10:38 AM
jimmhatch
32
Feb 11, 2007 12:37 AM
b19coupe
Aug 19, 2003 11:41 PM
Jared
Aug 13, 2002 02:10 AM
