extended wheel stud instal....help
Old Jan 21, 2002 | 09:57 AM
xJ.SLOTHx's Avatar
Default extended wheel stud instal....help
could someone,anyone just give me a few pointers on how to install wheelstuds on all four corners of my 90 si hatch. i have some skunk2 extended wheel studs lying around and i wanted to put them on when my car got out of the shop. any help would be appreciated. thanks.
Old Jan 21, 2002 | 10:01 AM
sgT's Avatar
sgT
Default Re: extended wheel stud instal....help (ian)
Rear are easy, just have to unbolt the hub and knock the old studs out and
put the new ones in. Front is a bit harder and requires the hub to be pressed out
and back in.
One word of warning, myself and many others have had problems with the
skunk2 wheel studs. they seem to gall quite easily even with antiseize.
Old Jan 21, 2002 | 09:01 PM
earl's Avatar
Default Re: extended wheel stud instal....help (sgT)
I've put front wheel studs in without removing the hub but it took a lot of creative work with a dremmel grinder.
Old Jan 21, 2002 | 11:49 PM
B18C-EJ1
Guest
Posts: n/a
Really? What problems have you had with the S2 units? Are they stretching the threads?
Old Jan 22, 2002 | 10:10 AM
C-speed's Avatar
Default Re: extended wheel stud instal....help (B18C-EJ1)
We use H&R studs.. no problems at all.. (H&R is about 1mi from where we are)
Old Jan 22, 2002 | 11:03 AM
DR. ON POINT's Avatar
Banned
Default Re: extended wheel stud instal....help (G3-TEG)
putting those studs in the front are so much easier with air tools....if not get a bunch of spacers an big wrench..ur gonna have to take the caliper off.....can someone enlighten me of why u would ut these studs in the rear????
SlowB16
Jun 11, 2008 07:00 AM
hamburgler
Sep 8, 2005 06:20 PM
b19coupe
Aug 19, 2003 11:41 PM
Tyson Ballou
15
Mar 1, 2002 06:31 AM
