water lines for turbo
ball bearing are oil and water journal bearing are oil.. some water and oil.. But anyways you can tap into the front of the block just below the exhaust port where the header bolts . there is a bold there you can take out for the feed.. and for draining the water tap into the radiator
^^lol. Not all of them. Ball-bearing chra are water/oil. On My gt3076r I'm running the b&r fitting kit which uses the the front port of the b series block and returns to the bottome of the radiator. easy effective and good price.
https://honda-tech.com/forums/forced-induction-49/turbo-coolant-line-kits-w-black-fittings-2014711/
yes im running a gt28 so its both i was thinking using the ports that go to the thermo valve on the tb since im running a aftermarket one and it has no valve
thats what ended up using. thank you very much honda-tech i am now turbo now i have to wait till thursday to get tuned. one question could i drive my car if the charge pipes aint hooked up? will be just like stock again?
