Having a problem with my 92 Civic. Need help.
Old Jan 27, 2010 | 07:36 PM
JoshMerchant's Avatar
Default Having a problem with my 92 Civic. Need help.
I have a 92' Honda Civic. Recently I noticed white smoke coming from my exhaust and whenever my car is idling it shakes really bad. Now I am sealing my head gasket tomorrow because I have a small oil leak coming from that. But I checked all my fluids and everything is full and running nice. I have been losing coolant and not sure why because I just replaced it. So I thought that was it but it wasn't because I added coolant and it still does it. I checked my motor mounts and they look good. I am not sure where this is coming from so if someone could help me or give me some advice on where to look I would appreciate it.
Old Jan 27, 2010 | 07:39 PM
eli92188's Avatar
Default Re: Having a problem with my 92 Civic. Need help.
check for any crarcks in ur head block hoses clamps things like that.
Old Jan 27, 2010 | 07:47 PM
Ok I will check that out tomorrow when my buddy comes over to seal the head. I mean I know basics about cars but I am no mechanic and this is my first Honda. But I will tell my buddy and we will check it out. So if something is crack just replace it? But what if nothing is cracked what else could be the problem.
Old Jan 27, 2010 | 07:50 PM
THEdumbGURU's Avatar
From: somewhere on the eastern seaboard in HoCo, MD
check all the coolant hoses and your radiator for cracks/ leaks. cuz that's most likely where all your coolant is going
edit: when you say "still does IT" does it refer to you losing coolant? if so my post is relevant
Old Jan 27, 2010 | 07:51 PM
ek4_b16a's Avatar
bad headgasket. your coolant is disappearing into your motor. it is drinking it up. does it smell sweet from your muffler?
Old Jan 27, 2010 | 07:57 PM
Yes it smells sweet. So how do I fix the coolant disappearing?
Old Jan 27, 2010 | 07:58 PM
i would start w/ a new head gasket if yours is in fact bad
I meant still does it as the shaking and white smoke. Because I thought it was shaking and the white smoke was because I was low on fluids so I added fluids and I still get shaking and white smoke.
Old Jan 30, 2010 | 12:06 PM
eli92188's Avatar
its deff either ur headgasket orr if u had overheated the engine u might of crackd ur head soo like theys guys said check headgasket
sammyb2120
Honda Civic (2001 - 2005)
Jul 20, 2015 07:04 PM
azz_kicker
Apr 16, 2006 04:59 PM
Intellect
Oct 15, 2004 12:30 PM
hondachick05
32
Jul 27, 2004 10:42 PM
integrx
Sep 2, 2002 10:47 AM
