swap help,opinions, guidance
Old Jan 27, 2010 | 05:02 PM
Rawl's Avatar
Post swap help,opinions, guidance
so i have a 93 civic hatch DX
the non V d series in it isn't cutting it at all
I absolutely going to swap
but what should i do?
i've been getting a lot of people saying b20
but i personally wanna go gsr or b16a2
but it looks like b20 is the cheaper route
any other recommendations?
any block/head combos i should consider?
i want power and i want to be able to daily drive it.
help me out
Old Jan 27, 2010 | 06:49 PM
mikej94civex's Avatar
Default Re: swap help,opinions, guidance
boost that d, or do a gsr swap...although the boosted d from my personal experience is alot cheaper, and provides alot more power, not done yet but in the process...don't go b20 my buddy has a b20z, the good one, in a 93 coupe and lost several times to a gsr teggy...
Old Jan 27, 2010 | 06:50 PM
homemadeturbo.com...orrrr hondaswap.com will lead u to water, but u my friend need to do the drinkin lol good luck
Old Jan 27, 2010 | 07:12 PM
THEdumbGURU's Avatar
From: somewhere on the eastern seaboard in HoCo, MD
gsr swap is going to be more reliable (since it doesn't have that turbo putting extra stress on the internals when you get on it)
Old Jan 27, 2010 | 07:40 PM
cafrog's Avatar
B20 wont fit without a LS IM and, in your car ECU, IM, TB, Dizzy, Injectors, engine harness and Alternator needs to be OBD1. So putting a low reving low hp motor in with all those changes is kinda silly. Most people that are telling you B20....they are most likely talking about a B20VTEC which is a hole other ball of wax (and tons more money to build it correctly....correctly...correctly). Do you have a specific amount of money in hand or is this a future thing? B16A2 is OBD2 as well.....so it would need relatively the same OBD mod's are needed to make it work too. Complete OBD1 swaps should be your focus....or plan on shopping and treasure hunting for various parts to convert an OBD2 motor over. Anyone says OBD2 is possible they are right but its a pain in the *** and takes way more then a straight OBD1 swap
Old Jan 27, 2010 | 07:45 PM
^^^well said. try to find a matching obd engine to make your life easier
Old Jan 27, 2010 | 07:50 PM
turbo-b20civc's Avatar
New User
i have a 97 crv b20 with a obd1 wiring with a type r head and it out runs gsr and b16 all day
Old Jan 27, 2010 | 08:22 PM
Rawl's Avatar
well i was able to pic up a vtec head for the single i have
but i was just reluctant to put it in but ive heard of some
people boosting the dseries and getting some good power out of them
around 14's without touching internals
now if i was to put the vtec head i know i would have to swap the ecu too
would the p28 do the job?
thanks for all the help
Old Jan 28, 2010 | 01:00 AM
mrharmonic's Avatar
becase he aint b20v
Old Jan 28, 2010 | 07:56 AM
P12 EG6's Avatar
ok the best thing you can do is get a complete swap from a supplier like Hmotors, i would go with a B16A swap (from JDM EG's) and if your happy with it just use that, but if its not enough power then buy a B20Z drop in cheap rs machine type r piston and put the B16 head and tranny on it and youll have a best csapable of running low 12's without spending over 4 grand.
Old Jan 28, 2010 | 09:42 AM
Rawl's Avatar
cool cool that sounds good
sounds like i gotta put in some
over time at work tho
Old Jan 28, 2010 | 02:35 PM
significant power gains = mucho money
Old Jan 28, 2010 | 02:56 PM
Rawl's Avatar
haha yea thats very true
theres really no to get power gains
without dumping a lot of money into the car
but its such an addiction that you just keep spending
in the end i saw it worth it tho
Old Jan 28, 2010 | 02:57 PM
^^it's always worth it lol
Old Feb 21, 2010 | 12:59 PM
cafrog's Avatar
It takes about $1,000 to build a Non-VTEC B series bottom end for a VTEC head and reving 2k rpm's higher (Frankenstein) Then you need to find a good machinist that builds these high rev'ing Honda motors. (Bearing clearances seem to be key...and ARP bolts) Shot peen LS rods should be the minimal priced rod you use. P30 is a great piston in an LS (piston ring gap and clocking is key)....aftermarket piston would be my pick for a B20, Not building an Non-VTEC and putting type r pistons in will work...until a bearing goes. Or...just stay below 7k and you'll be fine....but who in their right mind would do that? lol
captainkush
Mar 23, 2007 03:15 PM
JDean6pac
13
Feb 22, 2007 07:55 AM
sergionuneschang
Apr 23, 2004 08:13 AM
eNcI2iptI0n
Jan 22, 2004 10:07 AM
