my carpet is wet ... help please???
my carpet gets when when it started to rain the past 2 weeks in the valley (SJC). its only on the passenger side. the front gets wet. and the back gets wet too. what can be causing this??? like a hole on the bottom of the car or something?
Try and see if you can get a friend to run some water with a hose on the outside of your car while you sit inside and see if you can spot it, this is what I did and sealed the leak.
I have the exact same problem. In my EK its coming from under the dash on the passenger side. I'm not looking forward to pulling crap out to seal it but it will soon be a weekend project.
+1 on the hose idea. I will be doing something similar.
i had same problem with my car but driver side
and removed the carpet from the car and saw small hole by the fender and frame of the car thats how water was getting in got this fixed and now im good try and see wheres the water coming in
good luck
good luck
it could be the drain tube from your sunroof.. i had this problem and turned out the bottom of the drain tube was hanging in my car and not in the hole its supposed to be in.. good luck
DeDonDeRosa
Oct 5, 2011 06:01 AM
blu3g
Oct 7, 2008 09:02 PM
