What to do to my LS?
Old Sep 5, 2002 | 05:01 AM
RevinRex's Avatar
Default What to do to my LS?
I have a 90 LS block (B18A1) that I got for free. I want to build a N/A Monster with it and drop it in my CRX. Now I'm considering an LS/VTEC combination for more power! I'd like to get Toda Spec C cams and rev the darn thing to 9500 rpms! I'll be autocrossing/street driving this car too! Some people say that the Spec C's are too hard to tune? Should I just get the B's instead?!?!
Later on, I want to add ITB's if possible and manage it with a hondata ecu. I'm thinking of putting JDM CTR Pistons (.20 over) in the block wich should give me +- 11.9:1 compression with a B16A head. (right?) Or should I just get JDM ITR Pistons (.20 over) instead?
Now the whole reving part for the engine, I'll be adding a girdle to keep things solid on the bottom end and have the motor balanced and blueprinted. I'll also add some stronger/lighter rods to the engine while doing the engine rebuild!
My questions are as follows:
Will the engine be able to handle all the stuff I want it to do with it being properly built for it? Like rev that high? or at least up to 9000 rpms?
Will the ITB's be a good idea with the Toda Cams and high compression?
Another thing I haven't really tought about is what clutch and flywheel to get for my plans!! Any suggestions peeps? Toda clutch and flywheel? Clutchmaster? Exedy?
I just want opinions and toughts on the setup and also pointers or stuff I should consider getting or doing to the engine! Please show me some light on some possibilities! Any help will be appreciated! Thanks in advanced!
Old Sep 5, 2002 | 05:02 AM
RevinRex's Avatar
Default Re: What to do to my LS? (YBLegal)
Also, I'm planning on getting either a JDM ITR Tranny or JDM SiR Tranny for the swap. (forgot to mention that)
Old Sep 5, 2002 | 05:44 AM
b18b98's Avatar
http://www.b20vtec.com
Tthis should help a little.
Old Sep 5, 2002 | 06:10 AM
DevinW's Avatar
All i know is that it will be expensive... hehe
Old Sep 5, 2002 | 08:53 AM
RevinRex's Avatar
Default Re: What to do to my LS? (DevinW)
It will be expensive....but I can get parts for cheap. You know me man! lol!
How many people have actually used Toda Spec B or C camshafts?? I would like some input on how easy/hard they are to tune properly? Some say that the C's are really hard to tune. This true? Should I just get B's cause they are easier to tune?
[Modified by YBLegal, 1:53 PM 9/5/2002]
Old Sep 5, 2002 | 10:15 AM
DevinW's Avatar
Try instant messaging 'SIINSI' ...he has Jun III which I'm thinking would be similar..
Old Sep 5, 2002 | 11:51 AM
RevinRex's Avatar
Cool, thanks! I'll PM him tonight once I get home!
Old Sep 6, 2002 | 04:44 AM
RevinRex's Avatar
SINSI check you IM's if you read this!
TheCrimsonGhost666
Aug 17, 2009 01:47 PM
hahagasdcrx
Jan 9, 2004 08:18 AM
InfamousRS
Jun 12, 2002 05:02 AM
Lei Siew Long
May 9, 2002 04:54 PM
