AR Performance Turbo ITR 630whp@26psi E85
Old Jan 19, 2010 | 03:38 PM
VtecCarHauler's Avatar
Default AR Performance Turbo ITR 630whp@26psi E85
A quick video clip of the 1st baseline dyno pull on the wastegate springs after setting up the timing. The car was built by Casper from AR Performance and tuned by Lance HoLung. I did not get to stay and video the final pulls. The car ended up making 630whp@26psi on E85.
B18C block
84mm
B18C5 head
pro 2 cams
valve springs & retainers
Edelebrock IM
Turbo setup
BW 372 turbo
top mount mani
dual 44 tial wg's
1600cc inj
50mm tial BOV
3 inch charge piping
bar and plate intercooler
AEM
http://www.youtube.com/watch?v=GvW0apRvcDI
Old Jan 19, 2010 | 04:05 PM
I.C.C.'s Avatar
Default Re: AR Performance Turbo ITR 630whp@26psi E85
Nice setup... Thing should be good for some pretty big power
Old Jan 19, 2010 | 04:40 PM
alpha's Avatar
At $2.20/gallon you gotta love it
Old Jan 19, 2010 | 05:37 PM
ctr32's Avatar
sick!!!...how you like the 1600 injectors? any idle problem or anything?
Old Jan 19, 2010 | 05:55 PM
Rus1an's Avatar
Hows the idle with the 1600cc injectors?
What compression pistons?
Old Jan 19, 2010 | 06:01 PM
the idle was set at 1100 rpm I think. It sounds like a stock car at idle. I really didn't think about that until you guys mentioned it. I know the customer was very happy with the outcome.
Old Jan 19, 2010 | 07:22 PM
chrisdiz's Avatar
fuel pump setup?
Old Jan 19, 2010 | 08:24 PM
not sure I'll find out.
Old Jan 20, 2010 | 06:54 AM
AR Performance's Avatar
the car idles at 1000 rpm and fuel set up is aeromotive pump -10 in -8 return we will come back to the dyno when the customer is ready thank you scott for the vid
Old Jan 20, 2010 | 10:26 AM
There you go! The cams are pro 2's just remembered
Old Jan 20, 2010 | 10:35 AM
Teglove2's Avatar
how much boost?? Details!
Old Jan 20, 2010 | 10:46 AM
the video the boost was at 14psi and very low timing
final tune 630+whp @ 26psi
Old Jan 20, 2010 | 10:56 AM
cibao2ner's Avatar
any work done to ports on itr head? or just a valve job..and why such a big turbo for 630whp did it run out of fuel? and why pro2s not pro1 i though the pro1s were better for boost..
Old Jan 20, 2010 | 11:06 AM
DIABOLIC8's Avatar
Nice numbers
Old Jan 20, 2010 | 11:13 AM
-Yes the head has a mild p&p with upgraded valves,valve springs and retainers
-The owner of the car has never driven a vehicle with this much power so he is going to get use to the car then retune when he's ready for more.
-Pro 2's where used because that's what he had. Pro 1's are more than enough for any high hp setups but we just worked with what we had.
Old Jan 20, 2010 | 11:23 AM
Chef Andre's Avatar
HT's TOP CHEF
Nice setup.
Old Jan 20, 2010 | 11:42 AM
.CUBISH.'s Avatar
looks good Casper. With a set of pro1's it will probably make close to 700hp on the same boost. I tried the pro2 on the orange car and went from 870hp to 820hp
gotta love E85!!
Old Jan 20, 2010 | 11:57 AM
Teglove2's Avatar
Grrr...the closest e85 station to me is an hour away!!!
Old Jan 21, 2010 | 07:03 AM
thank you guys
Old Jan 21, 2010 | 08:53 PM
95skunkedgsr's Avatar
any street pulls for this sexy thing
Old Jan 21, 2010 | 09:33 PM
grenadelauncher's Avatar
New User
very nice #s Any other vids of it?
Old Jan 22, 2010 | 04:55 AM
I know they did a street run after the dyno. I do not know if anyone has video footage (if they do I'll post it). I hear the car's boost control/traction setup is awesome and that it barely has any wheel spin.
Old Jan 22, 2010 | 11:18 AM
e30_pilot's Avatar
New User
Dam i always hear good results from e85.
Old Jan 22, 2010 | 11:48 AM
boostedEF91's Avatar
good stuff
Infamous war
Jul 24, 2012 01:54 AM
92turbohatch430
Jun 22, 2010 10:00 PM
B18 CYA
May 31, 2006 07:01 PM
J.nguyen
May 29, 2006 12:32 PM
Turbowa
Jul 27, 2005 12:29 PM
