Turbo Feed Line oil Filter
I have one on every of my cars... It eliminates the chance of a turbo failure under occasions like debris from spun bearing, blown motor, oil lines breaking down internally, etc.. from entering the turbo.
I don't use the Earl's filters though.. I use finer miniature hyraulic oil filters from local hydraulic shops good enough down to 10 microns.
by tapping the feed line from a oil sandwich plate does the oil that goes threw the sandwich plate into the turbo feed line already filtered? does the port get oil Before or After the oil filter? In that case i wouldnt need the inline oil filter
^as far as that is concerned ALL oil filters have a bypass valve internal and the filter itself will bypass high pressure oil or cold oil... so no matter where your feed is from there is a risk of unfiltered oil reaching the turbo.
but yes, all honda filters have the bypass.
Yes, look at the design. They have holes around the center hole to pass oil to the filter. Once it leaves the filter, it enters the center hole and is routed to the ports from the center. You can see in this picture at about 11 o'clock and 2 o'clock where the passages radiate outwards from the center hole (where no small holes are).
It's a good idea to run a filter anyways, but a decent oil filter has to have some serious pressure or serious amount of debris in it to bypass. Usually when you get that much debris, you've already hosed your oil pump and it's not flowing any oil anyways. However, some Hondas can go over 80psi cold, and most oil filters will bypass oil around 60-80psi. I'd assume most companies know Hondas have high max oil pressure, and have stiff springs...
Yup, the stock oil filter still gets bypassed on a cold start because the bypass begins if pressure exceeds 60-80 PSI as mentioned, and also gets bypassed if oil pressure drops below a certain PSI as well. It works great too upon the first initial start, say after a fresh build with fresh oil lines and fittings. Sometimes you can't clean all the crap in SS braided lines after you've cut them, and sometimes you get stuff like traces of old gasket or sealant. I've seen all sorts of crap on my inline filters and I have been really cautious about keeping the lines clean as well.
If there is debris (and lots of it) from a spun bearing, or any form of engine failure, it will most likely take out the turbo as well and the stock oil filter will not catch everything.
It's always suggested to run an inline filter for the turbo, especially for dual BB folks. Some OEM cars come with pre-filters as well, such as the WRX STi. If anyone here has purchased HKS BB turbos, they supply you with an inline filter as a kit as well. It's just a good idea and just plan ahead the next time you install a new turbo. It's only about $60-100 more factoring in the fittings (depending on fittings used) and the filter itself usually.
And the best part, if some dude decides to tell you that your turbo has failed due to debris (warranty issue), you can tell the guy to go to hell because you have an inline oil filter.
I haven't done that before though, since I never had a turbo failure except for the really early days like back in '03 (so warranty was an easy thing). The other turbo related failures were rebuild-related so the vendor did some warranty work (not a GT turbo though). I am just saying this as an example...lol One less thing to worry about though.
http://store.forcedperformance.net/m...e=Acc-OilLines
Just ordered mine today, got the red on for journal bearing turbos! 80shipped..
Bit of a thread ressurection.
For the guys running the 10 micron filters, are they all good in terms of flow? Do they restrict the feed at all? Alot of the inlines I have seen are around 100 micron, but I want the most protection I can get.
A few places sell these in the U.K Demon tweeks, think auto etc. Mocal make one as do Goodridge.
I want to know if the 10-25 micron filters restrict flow at all.
Almost all inline filters have decent flow rating, especially ones that are meant to have 1/8" NPT inlets and outlets... I can assure you that 99.99% of the inline filters out there, whether it is 10 microns or smaller, would outflow a a common oil restrictor fitting... If you want to be 100% sure, than place a pressure gauge between the turbo oil feed fitting and the inline filter. As long as you get 35-50 PSI at the turbo, you are set.
Xerxes
Aug 28, 2004 02:02 PM
2000GSRT
Nov 10, 2002 06:38 PM
