constant reving help plz!
Old Jan 8, 2010 | 12:44 PM
QnzEP3's Avatar
Default constant reving help plz!
ok so i replaced my iacv brand new from honda about 2 to 3 months ago, i cleaned out the trottle body and got all the crap off of it, i took the air out the lines in the coolant and im having a problem that i thought would only happen with the older civics but im actually having the same problem i had on my old eg, my car when it sit sand is warmed up revs high, when it idles right it sits at about 800 rpm when i hit the gas quick it will hit 2000rpm drop down to 1000 and go back up to 1500 sit there for about 4 to 5 seconds then drop back down to 800, also if im driving and go into a complete stop it will idle like crazy with a constant rev, from 2000 to about 1200 then back to 2000 and back to about 1200 does it about 3 to 4 times in a row. idk wtf it could it but its driving me crazy, as far as the mods i have, i have a CAI aem, and thats really it. i have a check engine light for the primary o2 sensor that comes on once and a while, could it be a vacume leak? idk wat it could be, i never knew wat it was on my old eg either, but when i did the water pump and timing belt on my old eg it went away so i hope this has nothing to do with the same, please anyones help would be great....also when my car is fully cold and im in ny so the temp is about 10 to 20 degrees when i start the car i hear a grind like when u grind ur starter, i think the starters going but idk why it would make that grind noise
so to sum it all up
constant rev when cars standing still, grind when starting the car when its cold, check engine for primary o2 sensor, cold air intake and synthetic oil
Old Jan 8, 2010 | 12:51 PM
josh's ep3's Avatar
Function > Form
Default Re: constant reving help plz!
The grind is a common issue and is covered in a thread here in the section, just search for it. As for the idle issue, I'm not sure what it could be. The air in the system issue comes to mind but it seems like that's being taken care of...
Old Jan 8, 2010 | 12:53 PM
josh's ep3's Avatar
Function > Form
When you cleaned the throttle body I assume you took it off? When you put it back on did you replace the gasket? Check for vacuum leaks there.
Old Jan 8, 2010 | 02:14 PM
QnzEP3's Avatar
exactly how do u check for a vacume leak? and i replaced the gasket
Old Jan 9, 2010 | 05:37 AM
iv's Avatar
iv
One way is to cover the throttle body and see if the car dies right away if it takes a second you may have a leak it really only works for large leaks though.
Old Jan 9, 2010 | 11:37 AM
k20z1_types's Avatar
Why did you end up buying a brand new iacv? Just curious. Its also weird that your cel comes on from the primary o2 sensor. Have you ever had a RH or anything on that deleted your cat?
I had this same problem but after i took my iacv off and cleaned it out it worked perfect and still has for 2 years now. I had i/rh/e/rbc/kpro tho so it sucked alot of oil through the pcv which can cause it to gum up the iacv and cause build up.
Was there any oil in the manifold when you took the throttle body off or did you notice?
Old Jan 10, 2010 | 04:53 PM
QnzEP3's Avatar
the iacv is about 4 months old, i noticed a little bit of oil in the intake manifold but not much (i heard this is normal for an ep3) this all started when i put bad gas in the car, i put bp gas and the check engine light came on for the o2, did put the gas in again and it was fine, then 2 to 3 weeks later i had no choice so i put bp again and the cel came on again for the prmary o2, i nvr put it since and now i only put sunoco 89 (plus) nvr had a racing header or anything that would delete the cat
Old Jan 11, 2010 | 12:09 AM
QnzEP3's Avatar
Anyone have any idea? The car rev at bout 1800 to 2000 rpms when car is rolling in neutral then goes down to 800 at a complete stop...plz I can't figure this out !
Old Jan 11, 2010 | 12:30 AM
fasthatch95's Avatar
your throttle body is not closing fully. try adjusting the butterfly screw down and clean all inside of it 4 a clean close. when itz cold the butterfly sticks slightly so the car idles high and then rpm drops realy low when the car warms up. A lil vacuum thru the throttle make that.
Old Jan 11, 2010 | 08:47 AM
QnzEP3's Avatar
Ok ill try that, should I put a little wd40 on the trottle ? So it moves a little smoother?
Old Jan 11, 2010 | 08:53 PM
QnzEP3's Avatar
Anybody have. Any other type of inside mayb? I d k wat this could be, I've driven 152 miles since Friday when I did the idle relearn and no check engine light yet, I hope I didn't oder that o2 sensor for nothing
Old Jan 11, 2010 | 09:06 PM
kobeballer96's Avatar
shoott. i thought bp gas was good??? i put 93 octane at bp everyweek
Old Jan 11, 2010 | 09:16 PM
QnzEP3's Avatar
Yea I thought so to, I used 2 put bp all the time but I guess it gradually f*ed my **** up
Old Jan 12, 2010 | 06:26 AM
iv's Avatar
iv
Karcepts makes a block off plate that allows you to delete the IACV I use on my application and it works great even in cold weather. This will should fix your issue unless you have a vacum leak somewhere else.
Check it out here
http://www.karcepts.com/shop/categor...id_category=11
Old Jan 12, 2010 | 07:03 AM
QnzEP3's Avatar
Check it out here
Won't that throw a cel because there's no sensor attached to the iacv?
Old Jan 12, 2010 | 07:36 AM
trust me why did my si stay stuck at 2000rpms and tuch da gaz it stick even higher! when it warmed up it drop low az hell! Itz ur throttle body issue,take it off and basicly rebuild it like new. inside of ur tb plug the hole with the car runnen if it dies itz that leaking vacuum. Spanken new iacv need to get hot on the 1st time too. pull ur sensor frm it with car on if idle dropz its throttle vacuum problem.
Old Jan 12, 2010 | 12:45 PM
QnzEP3's Avatar
oo i heard if it dies then there isnt a varume leak
Old Jan 15, 2010 | 06:52 PM
ek_sleepr's Avatar
Check your TPS . if not check and see if your TB butterfly is working properly. it could be Both .
Old Jan 16, 2010 | 07:16 AM
iv's Avatar
iv
I keep forgetting I have K pro
Old Jan 19, 2010 | 08:11 AM
lmike6453's Avatar
I'm surprised that no one else has said TPS sensor. Check that and I would also suggest checking/reseating your IACV if it's relatively new it could be a leaking gasket where it sits flush on the intake manifold. Besides that, check vacuum air lines by spraying them when the car is on and see if you see any bubbles/inconsistancy in the fluid on the lines.
Old Jan 24, 2010 | 09:06 AM
ryanjvoss's Avatar
I wuld say f that bp gas, i cant believe u bought a whole new iacv and it still has unsteady idle most of the time u can just clean those and they're fine. Just pressurize the system to vaccum test and locate any leaks or loss of pressure. AND STICK WITH SHELL GAS, THE BEST
Old Jan 27, 2010 | 07:39 AM
v-dc5's Avatar
New User
try to reset the ecu
Old Jan 31, 2010 | 02:43 PM
jelcivic's Avatar
Have you disconnected the battery before the bouncing idle? If so you need to reset the throttle position. I had to do this with mine after I swapped motors. Start off by having the engine cold/disconnect then reconnect the battery. Make sure you have anti-freeze in the radiator/over flow. Make sure the climate control is on hot with the fans off. Start the car and hold the throttle at 3000 rpm until the fans have cylced twice. That will reset the throttle position. If you are still bouncing it may be the o2. I had the primary o2 bad and it would fall on it's face everytime I stopped. gl
uneek360
Jun 6, 2007 12:27 PM
Kyles ej1
10
Jun 11, 2006 02:36 PM
psyonicdeath
Jul 1, 2005 07:25 PM
0 0 0
30
Dec 18, 2002 06:25 PM
B_1_8_hatch
Sep 10, 2002 06:44 PM
