Push starting with an ignition kill installed…..possible?
Old Sep 4, 2002 | 06:11 AM
StolenSi's Avatar
Default Push starting with an ignition kill installed…..possible?
Just a thought….
If you had a kill on your ignition, and somebody tried to push start it, the kill wouldn't be doing anything right? Since I've never done it and don't know, how hard is it to push start a newer car with a hydraulic transmission (i.e. a 99 B18C5)? I realize these are probably stupid questions but I'd like to know before my electrical system goes under the knife this weekend.
TIA!
Old Sep 4, 2002 | 08:06 AM
owen_the_soyboy's Avatar
Default Re: Push starting with an ignition kill installedÂ…..possible? (StolenSi)
simple to push start the car (not that I know about the kill switch)
even a newer car is easy to puch start, you just need a lot of muscle or a hill.
get the car moving pretty well, in neutral, then slap it in gear, let out the clutch turn the key, and vavoom yer set to go.
depending on how the kill is wired, you may not be able to push start it.
Old Sep 4, 2002 | 08:08 AM
earl's Avatar
Default Re: Push starting with an ignition kill installed…..possible? (StolenSi)
If it is just a starter kill, you could push start it. If it kills the spark in the ignition, you can't push start it.
Old Sep 4, 2002 | 09:22 AM
martini's Avatar
Default Re: Push starting with an ignition kill installed…..possible? (earl)
depends on what type of ingition kill you are talking about.
if you are talking about a cheap battery cutoff, then yes, you could pushstart.
but if it's a properly installed, good battery cutoff (which would cut all power to the engine), then no, you couldn't pushstart it.
Old Sep 4, 2002 | 12:36 PM
hatchy's Avatar
Default Re: Push starting with an ignition kill installed?..possible? (martini)
What does a battery have to do with push starting? You can push start a car with a dead battery.
Old Sep 4, 2002 | 02:24 PM
carcala's Avatar
Default Re: Push starting with an ignition kill installed?..possible? (hatchy)
u need the battery to keep the car running. Ive tried it before when my battery died and the car wouldnt start even with a push start.
Old Sep 4, 2002 | 02:52 PM
sgT's Avatar
sgT
Default Re: Push starting with an ignition kill installed?..possible? (carcala)
No you dont. once the engine is running, the battery can be removed as the
alternator is supplying the power.
Old Sep 4, 2002 | 05:04 PM
martini's Avatar
*sigh* either I totally misunderstood his question, or you totally misunderstood what I was saying..
Old Sep 11, 2002 | 08:24 AM
StolenSi's Avatar
Just to clarify guys, I tried it out this weekend. Best bet was to kill the ignition, NOT the starter. It'll turn over but won't start, not even a push start.
[Modified by StolenSi, 9:25 AM 9/11/2002]
Old Nov 10, 2003 | 09:27 AM
GSRacer1's Avatar
Default Re: Push starting with an ignition kill installed?..possible? (StolenSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenSi &raquo;</TD></TR><TR><TD CLASS="quote">Just to clarify guys, I tried it out this weekend. Best bet was to kill the ignition, NOT the starter. It'll turn over but won't start, not even a push start.
[Modified by StolenSi, 9:25 AM 9/11/2002]</TD></TR></TABLE>
i was thinking of using a relay to do a kill switch for the ignition but cant find which wire to hook up
can any body tell me
Old Nov 10, 2003 | 09:42 AM
zanthrax's Avatar
So it depends on where the killswitch is placed.
It won't help if you placed it in the ignitionwiring. what would help is cutting power from your distributor or your fuelpump.
EF_LSVtec
10
Jan 27, 2017 04:36 PM
EF_Nina
Sep 30, 2011 02:15 AM
itslogz
Apr 4, 2010 08:21 PM
88 EF Hatch
Jun 27, 2009 06:52 PM
StreetRiot_DRE
19
Jul 26, 2008 10:25 AM
