Can't get timing right........????
Old Sep 4, 2002 | 01:49 AM
blackANESE's Avatar
Default Can't get timing right........????
I have a 2nd. Gen. B16 in a 93 civic dx hatch.
Well, my timing is very advanced and I can't get it right.
I put it at TDC, used a timing light, and jumped the ecu.
I also tried retarding the distributor side, but that didn't work.
It was still advanced about 5 degrees or so.
The motor is also idling really high (2100) then goes down
to around 1300-1500 when car is warmed up.
If anyone has any suggestions please help!
Old Sep 4, 2002 | 04:24 AM
Mikey3000's Avatar
Default Re: Can't get timing right........???? (blackANESE)
are you talking about ignition timing? if you are and you can't retard your dist. enough to get it to 15 (+-2) then your exhaust cam must be advanced. check on that. do u have adjustable cam pulleys?
Old Sep 4, 2002 | 08:47 AM
GruvyTune's Avatar
New User
also, if your idle is that high, then that will advance your ignition, so you need to get your idle down to see what your base timing really is. anything over 750rpm will have ignition advance put in by the ecu.
Old Sep 4, 2002 | 09:57 AM
CHEETAH's Avatar
Default Re: Can't get timing right........???? (Salvatore Leone)
i think he said b16 in there not h22 ... its intake cam.
greg
Old Sep 4, 2002 | 01:02 PM
HONDABROMANDUDE's Avatar
Default Re: Can't get timing right........???? (CHEETAH)
we pulled the valve cover off and checked all of the timing marks, the cam gears are still set at 0 and al of the crank and cam gear marks were lining up perfectly. What can we do to get the idle down far enough to set the timing right?
Old Sep 4, 2002 | 01:09 PM
Mikey3000's Avatar
greg
yeah....it was early....
Old Sep 4, 2002 | 03:32 PM
salbaje's Avatar
check your tps. if not tps your timing is probably off by a tooth or so.
Old Sep 4, 2002 | 07:06 PM
StyleTEG's Avatar
Default Re: Can't get timing right........???? (itec311)
Turn the idle adjust screw. You will have to disconnect the IAC valve's electronic clip for it to make any changes.
Treyschls
Apr 13, 2023 07:04 AM
bopbop93030
Feb 24, 2009 02:57 PM
johnwohl
Apr 1, 2008 07:29 PM
Mugen_DC2R
Jun 18, 2007 08:04 AM
LSVTEC 91 Civic
Aug 31, 2004 06:35 PM
