looking to know what kind of power i canmake with this set-up
sup guys/girls i got a stock gsr motor on the side and wondering what kind of whp i can make with the basic t3/t4 turbo kit bolted on with my blox turbo cams and 750cc injectors with a hard tune?? and what would be my next step to build
LOL!!!
Ok, I'll play the "good guy" here, and give you the heads-up before too many guys in here rip you a new one, or if this thread gets locked...
First and foremost, the purpose of your post is against the rules, as there is no "how much power will I make" threads allowed. Secondly, you are encouraged to SEARCH, there are tons of info in the FI FAQ's & stock GS-R turbo threads in this FI forum to gather info on, without starting a new thread, as tons of these types of threads are created each & every week. Third, not enough info was given. The "basic t3/t4 turbo kit" can become extremely broad, but with a Walbro 255 lph fuel pump and your 750 cc injectors, you will have enough fuel to make power within a stock GS-R's limits on premuim pump gas.
As far as your motor is concerned, if its healthy with good compression & leakdown, you will find that ppl are making a variety of whp numbers on stock GS-R's, ranging from 300 to 450 whp, depending on the type of fuel used. Assuming you're gonna be using pump gas, I myself would keep it at a safe 300 to 325 whp, but I dont know your purpose of the car, which you did not state. Do your research, select the proper turbo for the goal you decide on, and get you a good tuner. And as far as the Blox cams go, you dont need them, you'll be fine with your stock GS-R cams, should you stay in the suggested power range. Good luck.
