Looking for results with the BW T3 S362 ??
Old 01-26-2008, 09:20 AM
007EG's Avatar
Default Looking for results with the BW T3 S362 ??
I've been looking around at different turbos and have been trying to decide between a few. I know people are using BW but i'm specifically looking for results from people who are actually running or who have run the turbo.
Specifically the S362
T3
.70 a/r
Extended Tip Turbine
TIA
Old 01-27-2008, 10:29 AM
007EG's Avatar
Default Re: Looking for results with the BW T3 S362 ?? (007EG)
Guess nobody runs this turbo??
Old 01-27-2008, 11:57 AM
Man U FTW
Schister66's Avatar
What are your power goals and engine setup?? That would be a big help...Its a great turbo, but without knowing your needs, its hard to say whether or not it will be a great turbo for your goals/use.
Old 01-27-2008, 12:16 PM
007EG's Avatar
Default Re: (Schister66)
My power goals and engine setup arent needed for the question I asked. I know about the specifics of the turbos i'm looking at, and know it will fit my needs. I'm specifically just looking for anybody at all using this specific turbo and their results with it. Just want to see what peoples setups are and what kind of power their making at what psi. Looking to see the efficiency of it, spool times, IATs, etc.
Old 01-27-2008, 12:39 PM
Man U FTW
Schister66's Avatar
Spool time and power created is going to be determined by the engine setup, cams, manifold, etc...it DOES play a role
Old 01-27-2008, 02:35 PM
turbodano's Avatar
Default Re: (007EG)
Search the neon forums we just had a customer (Nemo) in Florida make 679@34psi on the .85 t3. He also went to the track and set the Neon 5 speed record with it. He went like 10.50 (I am not sure what the exact et is but that is what I remember him saying.) I know he was going to post up the dyno chart on the Srt forums.
Old 01-27-2008, 04:51 PM
007EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Spool time and power created is going to be determined by the engine setup, cams, manifold, etc...it DOES play a role</TD></TR></TABLE>
Yes, it does play a role. But not for my question it doesnt. I didnt ask for results with "x" manifold and "y" compression...etc. I just want to see how the TURBO can perform. Yes I would like to know the persons setup who is using the turbo, but based on my question MY setup is not important. If I told you my setup, will that tell you how this turbo performs on someone elses vehicle?? NO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">Search the neon forums we just had a customer (Nemo) in Florida make 679@34psi on the .85 t3. He also went to the track and set the Neon 5 speed record with it. He went like 10.50 (I am not sure what the exact et is but that is what I remember him saying.) I know he was going to post up the dyno chart on the Srt forums. </TD></TR></TABLE>
Thank you
Old 01-27-2008, 07:21 PM
Moderator
TheShodan's Avatar
Default Re: (007EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 007EG &raquo;</TD></TR><TR><TD CLASS="quote">
Thank you </TD></TR></TABLE>
I guess what we're saying is what good is all this "setup" information if the platform doesn't fit what you're trying to do? I've used that specific turbo on SEVERAL different cars. CFM flow is just that, CFM flow. Displacement, static compression, and benchflow of the head ALL play a part.. If you have SPECIFIC questions of the S362 on HONDA applications, give me a PM, and see what can work for your needs. Otherwise, you need to start looking at all optinos from other forums as turbodano suggested.
WhiteEJCoupe
07-29-2009 06:43 PM
norcalbayboy
04-25-2008 07:07 AM
alpalwal
08-19-2004 03:19 PM
GsRBubble1320
04-01-2004 02:26 PM
Quick Reply: Looking for results with the BW T3 S362 ??
