knock sensor issue
Old Jan 3, 2010 | 12:27 AM
daymkimchee's Avatar
Default knock sensor issue
My friends 97 prelude keeps throwing a cel for knock sensor after running the engine for 15 minutes.Could this be a engine issue or just a sensor issue?
Old Jan 3, 2010 | 08:34 AM
minilogoguy18's Avatar
Default Re: knock sensor issue
It's the sensor, the knock sensor CEL means that the engine can't find one, most likely needs to be replaced. My 4th gen did the same thing but luckily it was just the guy who helped with the swap had the wrong wires plugged to it.
Old Jan 3, 2010 | 03:56 PM
kulrevon's Avatar
The knock sensors are known to crack and break. and you are correct it wont immediately throw a CEL it throws it within a couple mins of driving.
Old Jan 3, 2010 | 06:22 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Happen to know which other plug is the same as the KS one?
Old Jan 3, 2010 | 06:41 PM
viper-blue's Avatar
The oil pressure sending wire is similar and they are very close to one another. Its a blue/red wire on the 4th gens. I'm pretty sure 5th gens are a two wire knock sensor though.
Old Jan 3, 2010 | 10:59 PM
It was the one for the air intake bypass, that black vacuum box beneath the IM, the plugs were the same.
Old Jan 7, 2010 | 03:50 PM
thanks for the info i was worried it was reading somthing wrong with the motor
Old Jan 7, 2010 | 04:28 PM
Na, if the knock sensor was working and doing it's job and there was something wrong with the motor you'd be getting misfire codes, the knock sensor code means there's something wrong with the sensor itself.
Old Jan 7, 2010 | 08:28 PM
thanks a million
SuperBowser707
Dec 4, 2012 07:49 AM
iNtEgRaGsR19
Jan 20, 2007 08:04 AM
s_vares
Sep 3, 2006 02:54 PM
qwklude82
Jan 13, 2003 06:00 PM
