How to disable knock sensor?
Old Jan 12, 2003 | 08:36 PM
qwklude82's Avatar
Default How to disable knock sensor?
I have a 5th gen prelude with a built bottom end. I'm pretty sure the noise from the engine is coming from the forged pistons. However I can't break the motor in b/c of the stupid CEL that comes on from the knock sensor. Can someone explain how to disable the stock knock sensor? Sorry if this is a repost.
Thanks
Old Jan 12, 2003 | 08:38 PM
Kamin's Avatar
Default Re: How to disable knock sensor? (qwklude82)
chipped ecu is the only way i know of.
Old Jan 12, 2003 | 09:06 PM
tnbigdawg's Avatar
Default Re: How to disable knock sensor? (Kamin)
I've heard that you can ground the knock sensor wire. Not sure if it really works though.
Old Jan 13, 2003 | 07:47 AM
qwklude82's Avatar
Default Re: How to disable knock sensor? (tnbigdawg)
Does grounding the knock sensor wire work? Also i kinda need this to be temporary since I have a Hondata waiting for me after i break the motor in.
Thanks
Old Jan 13, 2003 | 10:29 AM
qwklude82's Avatar
Ok really quick question. I'm starting to get confused. Will piston slapping cause a CEL with the knock sensor? Just need a yes or no answer b/c it seems some people are saying that a CEL with the knock sensor means either the wiring or the KS is bad.
Old Jan 13, 2003 | 10:55 AM
tnbigdawg's Avatar
okay, I just found out. you need to have the knock sensor hooked up, but you can ground it instead of hooking it onto the block.
Old Jan 13, 2003 | 04:47 PM
SuperSH's Avatar
Glad to see you finally have your car somewhat running.
Old Jan 13, 2003 | 06:00 PM
qwklude82's Avatar
Default Re: How to disable knock sensor? (SuperSH)
sup whitney...yeah its coming along...at least this is the only code its throwing right now. Thanks for all the help
SuperBowser707
Dec 4, 2012 07:49 AM
97blacklude
Jan 31, 2009 09:56 AM
DumpedSi
Aug 10, 2003 08:30 PM
delslow94
Dec 26, 2002 12:52 PM
