Suspension & Brakes Theory, alignment, spring rates....
Progress Coilover Systems
Old Dec 20, 2009 | 01:28 PM
chrisff521's Avatar
Default Progress Coilover Systems
Has anyone ever tried using these? Are they strong and give a smooth ride?
http://www.vividracing.com/catalog/p...0-p-74753.html
Old Dec 20, 2009 | 04:53 PM
_willis_'s Avatar
Default Re: Progress Coilover Systems
i just got mine on a few days ago, so far i love them!
... not sure if you know though, that link you posted is for the aggressive spring rate kit, if you are wanting them for your street car, then i would look at the more friendly 350/250 springs
info/pics/better price:
https://honda-tech.com/forums/wheels-tires-brakes-suspension-48/progress-coil-over-special-promotion-2692801/
Old Dec 21, 2009 | 12:31 PM
JW racing's Avatar
I am very close with Progress and have run their stuff on my H1 car for sometime now.They are very comparable to high end shocks for the price and progress can valve to your desired spring rates as well.
What are your goals and usage for the shocks,then we can help guide you towards the right setup.
Old Dec 21, 2009 | 01:36 PM
rota92
Guest
Posts: n/a
Progress
Old Dec 29, 2009 | 09:32 PM
chrisff521's Avatar
im just using them daily driving and i want to be able to adjust the height pretty low cuz i like a low ride but dont want them to get bouncy after a while from being too low. Can I use bigger top hats with coilovers to get a longer piston travel?
Old Dec 29, 2009 | 09:43 PM
sayyoooon's Avatar
how low are you trying to go exactly? the shock bodies themselves are already shorter. heres what the rep told me.
Originally Posted by Progress Technology
Our damper housings are (about 30mm) shorter than OEM. The rod is also shorter than OEM. I see no benefit in running another confuguration top hat. We designed the strut with to use the OEM top hats.
The issue that MAY arise (if the extended hats are used), may be that they COULD reduce the necessary DROOP travel (extension) too much. This is only a thought, as we have not needed to go this route. The CS-IIs have plenty of wheel travel, if not lowered beyond about 2.0" or so. I hestitate to post this "2.0" number, as we have a wide range of road conditions, and some owners need more travel than others...
Regards,
Progress staff
Old Dec 29, 2009 | 09:45 PM
chrisff521's Avatar
yea i was just reading that also. I wanted about a 2" drop maybe more if they can handle them.
Old Dec 29, 2009 | 09:47 PM
chrisff521's Avatar
And where would I get new OEM tophats anyways as my current factory ones are pretty beat up and falling apart.
Old Dec 30, 2009 | 04:44 AM
blaze the chemi's Avatar
I have looked at the progress parts for a while since I am considering getting a setup for my wife on her 96 Accord with all original shocks and springs. I think they have good quality stuff.
OP:
Are your top hats beat or the bushings beat from the springs? Your top hats should be fine, but I would at least consider replacing the bushings between the spring and top hat. You can get them from your local Honda dealer pretty cheap I imagine.
Old Dec 30, 2009 | 06:18 AM
DrZFiNeSt's Avatar
I am in the process of getting their coilovers as well.So far I have heard nothing but good stuff about them
Old Dec 30, 2009 | 10:00 AM
sayyoooon's Avatar
since the bodies are already shorter, you'd not have to drop the actual springs too much. they should be fine easily.
nxvictim
Suspension & Brakes
Nov 5, 2007 05:48 PM
moores55
Jan 15, 2006 12:37 PM
alb_accord
Jul 5, 2004 11:50 AM
PM-Performance
22
Jul 8, 2003 02:55 PM
G2Integrity
12
Sep 13, 2002 07:35 PM
