Questions about dual gates and controlling boost
Old Dec 17, 2009 | 06:28 PM
TurboCivic11's Avatar
Default Questions about dual gates and controlling boost
So im running a top-mount manifold with dual tial 44's. I tried putting a manual boost controller on it that i verified works on 2 different cars. Everytime it went striaght over 30psi. So i went back to running WG spring pressure which is about 20psi. This season im gonna be using eCtune, and not sure what i need to run the gates for the gear dependant boost control. Like do i need 2 solenoids, 1 for each gate? i was told i cant run a manual controller on dual gates so i gave up on that pretty quick. Any info or help would be great.
Old Dec 17, 2009 | 06:39 PM
hybrdthry911's Avatar
Default Re: Questions about dual gates and controlling boost
you got it all wrong, you can treat dual gates just the same as single gates. ive got a manual boost controller on my dual gate setup. just run a single line into the boost controller, and tee off after the boost controller to each gate.
Old Dec 17, 2009 | 06:44 PM
Thats what i did,i used 2 different manual boost controllers and both did the same thing. Went straigh over 30psi no matter how much i turned them in to turn em down. Ant then i talked to a couple guys that have dealt with stuff like this before and said it doesnt work when you use a manual on duals. No t sayin your lieing by any means, just dont understand why mine didnt work. I would have turned the boost up over 20 if it had lol. I went 10.6 on 20psi and pump just cause i was told i needed an electronic.
Old Dec 22, 2009 | 02:45 PM
bump for some help. any diagrams or info.
Old Dec 22, 2009 | 10:36 PM
Silva Bullit DC4's Avatar
What two brands did you use? What were you using for reference source, boost or vacuum?
Old Dec 23, 2009 | 08:56 AM
you must have it hooked up wrong. you arent running any lines to the top of the wastegates right?
ericstambaugh07
Apr 7, 2007 12:45 PM
5thGenCivicKid
Mar 26, 2005 11:40 PM
xxscaxx
Feb 21, 2005 04:13 AM
Tofurky
Aug 6, 2002 10:11 PM
SIK IN DA HED
Sep 13, 2001 03:16 AM
