How to up Boost??
Old Mar 26, 2005 | 09:46 PM
5thGenCivicKid's Avatar
Default How to up Boost??
how to up the boost on internal wastegate??? i have no clue how to do it im only running 5.5psi on a t3 super 60 and i need more boost
wow i miss hmt!
Old Mar 26, 2005 | 09:50 PM
Evanmb44's Avatar
Default Re: How to up Boost?? (5thGenCivicKid)
get a manual boost controller
or
you should be able to turn the rod on the actuator on way or the other i beleive
someone correct me if im wrong with that one
Old Mar 26, 2005 | 10:01 PM
Default Re: How to up Boost?? (Evanmb44)
i have a manual boost controller but if the gate is only set at 5.5 how to i get it up?
Old Mar 26, 2005 | 10:14 PM
turboda6's Avatar
you get it up by minipulating the wastegate. let it see less vaccume thus creating more boost. if you vent off the vaccume then the wg see's less vaccume thus not opening all the way thus creating more boost. read the manual that came with ur manual boost controler.
Old Mar 26, 2005 | 11:40 PM
cnydc2's Avatar
If you have a manual boost controller yoiu should be able to get at least 10psi out of the gate. If you are not getting this you either have it hooked up wrong or the boost controller is broken. I use a Greddy Profec B and it is a great unit, it's very easy to hook up and is very easy to operate.
chrisgottigsr
Dec 18, 2005 05:00 PM
xxscaxx
Feb 21, 2005 04:13 AM
LudEcrous
Sep 8, 2004 08:21 AM
zseeanz
Nov 11, 2003 07:50 PM
Tofurky
Aug 6, 2002 10:11 PM
