Gasket on dumptube?
Hey guys just curious if I should run a gasket on my dump tube? im not running one on my wastegate. if anything should I just use some gasket maker ? or nothing at all?
Thanks
Thanks
if you dont have a v band, it ie beneficial to run one on the gate to manifold at the very least. if it dies leak there you will be down on boost, or it will lag more than it needs to.
you dont need one on the dump, but if there is anything in the way, it may get a little jet of hot air.
make sure it is clear all the way around.
B16Civic93
Nov 24, 2005 05:17 AM
