car sputters and bogs after turbo
Old Dec 4, 2009 | 11:54 AM
NmaynarD's Avatar
Default car sputters and bogs after turbo
Have a h22 in EK civic and it ran great all motor. Had CEL 10 & 14 but the car still idled fine and drove great all motor. So I decided to boost it. So I added all the necessary parts including a walbro 255 fuel pump. That was the only thing I added besides the turbo stuff, and injectors. I got a chip just so I could drive it to the tuner.
Now to the problem....
The car runs like dog turds. I can't give it more than a TINY bit of throttle. Not even enough to get the car up to speed fast enough to feel safe driving it on the main road. If I give it more than that it breaks up and won't go above about 4k rpm. It idles good enough and doesn't die or anything. I pulled the plugs and they were white as hell. So it's running lean right? So I put some bigger injectors in and now it's running pig rich but still doing the same exact sputtering/bog as with the smaller injectors.
I have ZERO vacuum leaks. And like I said above I have the 10 & 14 CEL. Had them when it was all-motor and it ran perfect.
I know getting it tuned will probably fix it but just wondering if it could be something else. I'm on a tight budget and was not wanting to spend money to tow it 2hrs to the tuner. I had no plans of hitting boost until after a tune, just wanted to be able to drive it there.
Any and all help is appreciated!!
Old Dec 10, 2009 | 06:09 PM
boostedblkef's Avatar
Default Re: car sputters and bogs after turbo
what injectors?
Old Mar 17, 2010 | 06:58 PM
krobie's Avatar
did u ever find out wat was wrong with your ek? i got the same problem in my ef wtih ls swap!
bluedragon
Oct 29, 2016 03:38 PM
DRIVENRacing
Honda Civic (2001 - 2005)
10
Feb 11, 2010 08:11 AM
98EK
Nov 29, 2004 10:47 PM
MachAF
Jun 28, 2003 07:23 PM
internet ay
Dec 20, 2001 09:42 AM
