turbo help. car throwing CEL
Old Jun 28, 2003 | 02:12 PM
MachAF's Avatar
Default turbo help. car throwing CEL
Well I was having problems with my injectors leaking fuel. Well I had a few messed up o-rings. Replaced those with the stock ones. Put the injectors back in.
Car started fine. I drove the car across town to get my hair cut. After my hair cut I come back out and try and start it, it doesn't want to start very well, when it does it throws a CEL, then dies. Now it starts hard and won't idle unless I rev is, but its running like ****, and spitting smoke out the back when I rev it. Its 100 degress outside, and everything in very hot. I hope its just a fuel or ignition problems. And not a blown headgasket, but I don't see how the headgasket would go. I've had the kit for like less than 100 miles.
I haven't checked the CEL yet. I'm at home now and my car is still across town. I'm going to go check the CEL's out when my dad gets home.
I feel like complete **** right now. I don't even want the turbo anymore.
Anyone have any guesses to the problem?
I'm using greddy blue box 310cc injectors and blue box light is flashing green.
Old Jun 28, 2003 | 02:15 PM
Mr. Softee's Avatar
Default Re: turbo help. car throwing CEL (MachAF)
pull the CEL, it only takes a few minutes and will help us a lot.
Old Jun 28, 2003 | 03:20 PM
RuthlessEF-9's Avatar
Finding out the CEL should be your first priorty more than anything else
Old Jun 28, 2003 | 03:26 PM
MachAF's Avatar
Default Re: (D16z6turbs)
Yep. I'm going to do that ASAP! Thx guys
Old Jun 28, 2003 | 03:27 PM
Spudddy's Avatar
turbo's ab itch until you get things figured out then you'll love it for ever and ever
Old Jun 28, 2003 | 07:23 PM
MachAF's Avatar
Default Re: (Spudddy)
Okay I was getting CEL 71 and 73.
Misfire in cylinder 1 and 3.
Problem was I crushed an injector wire while tighten down the wire harness thingy that goes on top of the fuel rail.
I check the wire where it was crushed and it seems to work fine now. Except it was smoky for about 2 miles, then stopped. I'm guess thats just excess gas.
The engine is not all bouncy now. And no CEL's.
jsb8096
May 16, 2012 12:14 PM
JDM*Fiend
Jan 6, 2010 10:49 AM
gftgrill
Oct 27, 2005 12:10 PM
Easyslider01
Oct 9, 2005 11:44 AM
freeplay
Oct 20, 2002 09:05 AM
