motec plm
Old Dec 17, 2001 | 10:38 PM
internet ay's Avatar
Default motec plm
i just wanted to post that my friend just got the motec plm and that thing is amazing. he has two cars he used it on today, he has a 2nd gen gsx and a 89 civic hatchback. first we took out the gsx with the plm and used his pms to correct the air fuel ratio and found out that his car was running rich throughout boost. we took like 5 full throttle runs and i swear the car got like .5 seconds faster in the QM, and it only took like a half hour. then we took out his hatcback which has a crx si motor in it with his custom turbo setup and built motor, the problem with this car was he is running 660cc injectors and a zdyne secu and he could never even get the car to barely idle. well we got the car started, plugged in the motec and the labtop for the zdyne and took her out. before when we took it out it ran like **** , sputtering and stuff, well we took it out to find out the car was running way rich and took a couple wot runs and messed with the zdyne and the car started running soooo good it was sweet. so the point of this story is this thing is awesome, a good tuning tool and very accurate and worth the money he spent. i just felt i should share this with the rest of the board.
Old Dec 18, 2001 | 04:12 AM
d mafia's Avatar
New User
Default Re: motec plm (internet ay)
Is this Motec PLM a A/F Analyser? How much does it cost?
Old Dec 18, 2001 | 05:18 AM
DirtyLude's Avatar
Default Re: motec plm (2FAST4U)
The best/lowest price amateur lambda sensor out there right now is the FJO one.
http://fjoinc.com/automotive/products.htm#wbo2
At ~$800.00 for the package, you just can't beat it. It's a properly calibrated UEGO sensor.
After that I would probably go for the M&W controller/UEGO sensor.
Old Dec 18, 2001 | 05:29 AM
ZygSpeed's Avatar
Default Re: motec plm (DirtyLude)
Matt -- nice avatar,
But what is the Motec plm, ... is that the Palm or PDA based analyzer that was in the banner ads?
And, how did he "plug it in" to both a Honda and a DSM (separate connector cables?)
DirtyLude -- I should know this, but what does UEGO stand for?
Thanks ... ed
[Modified by zygspeed, 9:30 AM 12/18/2001]
Old Dec 18, 2001 | 08:14 AM
DirtyLude's Avatar
Default Re: motec plm (zygspeed)
Universal Exhaust Gas Oxygen (UEGO)
It's a very fast, very accurate wideband O2 sensor. Any controller you buy should be able to take the calibration chips that are sold with the sensors. There's a good technical article here:
http://www.tagelectronics.co.uk/Prod...ion/Lambda.asp
Old Dec 18, 2001 | 08:52 AM
Xerxes's Avatar
New User
How much did the Motec one cost your friend? I've seen it listed for $1200...
I've been thinking about getting some sort of wideband O2 for use as a tuning tool with my Hondata.
There's some neat information on the Hondata web site about using the Motec meter in conjunction with the software.
Check out this short video clip! http://www.hondata.com/media/lambda_maptracing.mov
here's the page with all the info http://www.hondata.com/motecplm.html
Old Dec 18, 2001 | 09:27 AM
ZygSpeed's Avatar
Thanks Guys!
Old Dec 18, 2001 | 09:49 AM
yeah its definately cool that it can go from a dsm to a honda. the display is like the size of like pack of cigarettes and it displays the air fuel,very accurate the second he would make a change on the pms the air fuel # would change almost immediatley. i think he paid like 1200 for it but i am sure he will make some of his money back when he lets other people use it for $.
Old Dec 18, 2001 | 10:17 AM
DirtyLude's Avatar
I would recommend the FJO over the Motec. Cheaper; does exactly the same thing. 5 watt output, rs232 output, and 3 digit display. You can get the software to datalog the runs against RPM if you don't have a 5watt input on your standalone, or don't have a standalone at all.
Old Dec 18, 2001 | 11:35 AM
Xerxes's Avatar
New User
does the FJO have an O2 voltage output like the Motec PLM? I know that for Hondata and probably many other standalones, you can hook up a single wire from the control box to the ECU. The wire contains an analog voltage that corresponds to the lambda value, for tuning purposes...
-Xerxes
Old Dec 18, 2001 | 12:02 PM
DirtyLude's Avatar
Default Re: motec plm (Xerxes)
Yes, it has a standard 5 volt signal output.
Old Dec 18, 2001 | 04:47 PM
Xerxes's Avatar
New User
sweeet.. i may have to buy myself one of these things for christmas!
So I was wondering, how do you hook this up to your car? Can you just unscrew your factory o2 sensor and screw the wideband one in? (assuming your ECU supports running open loop w/o a standard o2 sensor)
-Xerxes
Old Dec 18, 2001 | 09:28 PM
that is what my friend was doing because he didnt get around to welding a bung on the 2 cars downpipes. but i am not sure if you can do this on any car because he had a zdyne on one and pms on the other so i dont see this working on a car with no ecu management.
Old Dec 19, 2001 | 04:15 AM
d mafia's Avatar
New User
What about the Blitz A/F Analyser. It comes with a wide band O2.
Old Dec 20, 2001 | 09:42 AM
Xerxes's Avatar
New User
Yeah well my Hondata will let me run without the stock o2 sensor, i just wanted to see if the threads will physically match up.
This is really sounding like a good buy now, if i can get it for $800 and then make a couple hundred lending it out to friends, then it will definitely be worth it compared to spending tons of $ on the dyno. (I've already spent nearly $400 on the dyno and i need to go back)
-Xerxes
NmaynarD
Mar 17, 2010 06:58 PM
BigDare23
Mar 16, 2010 04:56 PM
gt35rSI
Nov 3, 2007 12:35 AM
Crxlsturbo
Aug 12, 2001 12:02 PM
