To port or not to port, Please advise!!
Old Nov 28, 2009 | 03:16 PM
shanebadoo's Avatar
Default To port or not to port, Please advise!!
Hello all. I'm in the process of building my b18c motor, most of the bottom end work is finished. I'm shooting for 450 wheel bhp. My specs:
cp 9.0:1 pistons 81.5
stock 87 stroke
Eagle Rods
Gt3076r .63 back I'm using a quick 4 mani.
I really can't decide if to port or not. I have been reading on Evans tuning and a lot of the guys there doing big numbers don't mention porting at all. I have a (p72) stock gsr head, please advise if I should port for 450 bhp?
Also anyone that got a P&P, was it worth it, i mean could you feel the difference or at least did the dyno say it gained significant horsepower? Thanks all.
Shane
Old Nov 28, 2009 | 03:18 PM
boostedEF91's Avatar
Default Re: To port or not to port, Please advise!!
honestly you dont need to port it save your time and money... stock head with type r or ctr cams will get you your hp goal fairly easily..
Old Nov 28, 2009 | 07:37 PM
hybrdthry911's Avatar
save they money on port work and sleeve the block.
Old Nov 28, 2009 | 08:58 PM
E85B18's Avatar
Perfect advice!
Old Nov 28, 2009 | 09:11 PM
reactiondc2's Avatar
Def dont need to port it for your goals...Ive seen over 800whp on a stock port and cam 2 liter b18c
Old Nov 28, 2009 | 10:15 PM
runsfromdacops's Avatar
you dont need to do any port work to hit your goals. but you will make more power sooner in the rpm range and at lower boost with the port work. i would spend the $$ on sleaveing a block
Old Nov 29, 2009 | 09:17 AM
DA TeG 90's Avatar
+1.
Old Nov 29, 2009 | 07:25 PM
Turbo-LS's Avatar
yeah i finally convinced my buddy to not port his head, its just not worth it unless your building an all out drag queen and trying to extract every last drop of power from the setup. like already stated save the money or sleeve the block
Old Nov 29, 2009 | 08:10 PM
canteengreen's Avatar
85mm bore and some thick sleeve's are your best freind.im only makin 366 on 18psi and a sleeved block but the turbo u are useing is much bigger than mine
Old Nov 29, 2009 | 08:39 PM
dustin528's Avatar
you can make alot of power on stock port, but a ported head will always help. I would definetely get a sleeved block before a ported head. You can always get a ported head later on.
Old Nov 29, 2009 | 09:00 PM
why would you go 85mm when buying a sleeved block...you have no room to play with if you happen to scare a wall.. 84mm or less.. always leaves you room to go bigger if needed.. just my .02cents
biglurktm
Jul 21, 2015 08:32 AM
OMG THE GOGGLES
10
Sep 19, 2008 09:38 PM
B6tizzleHatch
Jan 5, 2007 12:27 PM
turbo hybrid hatch
Jan 22, 2002 07:35 PM
InfamousRS
Dec 20, 2001 09:23 AM
