Turbo water lines?
It's a 3/8" NPT to -6AN orbital fitting.
B16 thermostat housing with the intake manifold port drilled and tapped for 1/4" NPT. These are the only pictures right now, but you can get the general idea by putting the picture together.
Wow, this seems to be beaten like a dead horse..
T'ing off the heater hoses is simple, cheaply done with parts from Home Depot, and lines are about the same size as most turbo water line fittings.
i forgot to take a pic..lol I will tomorrow. your making it to difficult. You can either use the illistration the guy said or what i said. i think my way looks the cleanest and efficient
since you keep asking...the answer is no. the lines need to go to seperate places so the coolant can flow through the hosuing. if both lines ran to the same place the water would just "sit" in the turbo not providing any cooling.
Its a very easy principle. As long as its at least "inline" with a coolant hose it should work. Fluid convection causes the coolant to move through the system and carry heat away from the turbo.
does that help?
2000vsm
Aug 25, 2003 07:14 PM
