Help running coolant lines to turbo
Old Oct 19, 2012 | 03:36 PM
EJ8Squad919's Avatar
Default Help running coolant lines to turbo
Just bought a gt35r and im confused where to run the lines. I saw that b&r makes a kit but im looking to do the other off the tb or something. My problem is that im using a blox 72mm and it doesnt use a coolant line to the tb. So do i use the hose that would go to the throttle body as the feed? Now what hose do i T to use as the return?
Old Oct 19, 2012 | 03:57 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Help running coolant lines to turbo
Parallel:
'T' from the inlet to the heater core to the inlet of the turbo.
Outlet of the turbo to a 'T' on the outlet of the heater core.
Series:
Run the line that normally goes to inlet of heater core to inlet of turbo.
Outlet of turbo then goes to the inlet of the heater core.
- you can also do this at the throttle body
nekkedR
Jan 14, 2004 01:19 PM
GruvyTune
Sep 6, 2002 05:09 AM
T25 civic
Aug 27, 2002 08:11 PM
WEPN R
Jun 12, 2002 12:02 PM
SilverLudeSi
Jan 29, 2002 06:20 PM
