B18c type r wont rev up
Old Nov 18, 2009 | 10:08 AM
95itr-ej2's Avatar
Default B18c type r wont rev up
Hi people i just completed a jdm integra type r swap into a 95 ej2 shell, i used a vti (english dohc vtec)dash loom and kept the integra type r engine loom, i am use a obd1 to obd2 ecu jumper on it and i have the ran the knock sensor wire, and electronic load dector wire, as the vti loom did not have them,
now here is the problem, when i start the car from cold it fires up and idles like it shoud and revs up fine, but after about 1minute it wont rev up right, slow to rev up, it also strugles to run,
i have tried different dizzy, map sensor, and air temp sensor but they all are fine, also when car does rev it tends to back fire a bit,
can anybody please help thanks
Old Nov 18, 2009 | 10:28 AM
HRTuning's Avatar
Default Re: B18c type r wont rev up
Check fuel pressure.
Old Nov 18, 2009 | 02:20 PM
95itr-ej2's Avatar
wat pressure shold it be at??
Old Nov 18, 2009 | 02:22 PM
teamjdm239's Avatar
yup, i agree with HR. seems like a fuel problem.. do you have a f/p gauge? whats the reading after it tends to run rough?
Old Nov 19, 2009 | 12:33 PM
95itr-ej2's Avatar
i dont have f/p gauge i am ordering one now, i took off fuel line on the injector rail had a friend block the pipe with his finger, put on the ingition on it had enough pressure to push his finger off!!!!!!!!!
Old Nov 19, 2009 | 02:15 PM
Civic92Turbo's Avatar
make sure you have the right connector in the right place, or check your spark plug wire to insure they are in the right cyl.
Old Nov 25, 2009 | 05:36 AM
95itr-ej2's Avatar
ok i found the problem, it was the cam timing slipped the belt
derrickkong888
Aug 28, 2012 06:43 PM
brianfromhawaii
Jun 16, 2009 11:44 PM
vtec25
May 15, 2006 02:07 AM
hondapwr
Sep 12, 2004 06:11 PM
Driven
Sep 1, 2004 12:36 PM
