mini me need help
Old Nov 17, 2009 | 03:13 PM
darowdyest's Avatar
Default mini me need help
ok so i did a mini me swap. i follow the many write up on here. this is a 00 hatch with the d16y7 with a d16y8 head. Now i got it running but really crappy. im using a p2p ecu. i was wondering if the cam gear on the y7 is different from the y8 cus im using a y8 one an im sure the timing is off. i was getting misfires den i retarded the dizzy all the way now im not getting a cel but it idles really low. any advice or comment is appereicated.
ps im using y7 intake mani for now.
Old Nov 17, 2009 | 03:54 PM
chris worley's Avatar
Default Re: mini me need help
check out the forums on d-series.org. its dedicated to d series motors and there is a ton of info on there for this swap
Old Nov 17, 2009 | 06:10 PM
wmac's Avatar
y7 an y8 use the same cam gear.
you may be off by a tooth if it runs that badly.
the y7 intake manifold sucks, get rid of it. also y7 injectors are 190cc instead of 240cc that your p2p ecu thinks it has, so you are probably running lean.
Old Nov 17, 2009 | 06:19 PM
matt j's Avatar
sounds like you are off a tooth on the timing, recheck that and let us know and are you using the y7 injectors as well?
Old Nov 17, 2009 | 07:40 PM
darowdyest's Avatar
no i am using y8 injectors. i am kinda stump i check the timing like 3 times. every time is like half a tooth or a tooth off...getting soo frustrated. thanks guys for the input...i still need help. with the dizzy all the way retarded i have no cel runs crappy n low idle.
Old Nov 17, 2009 | 07:42 PM
darowdyest's Avatar
yea the y7 manifold is a temp. got the y8 coming soon.
Old Nov 18, 2009 | 11:00 AM
darowdyest's Avatar
does anybody know id the dizzy is 180 out would it still start? but crappy?
Old Nov 18, 2009 | 11:30 AM
CivicSpoon's Avatar
You can't install the distributor 180 out. The groove is offset, so it only goes on 1 way.
G Jones
Nov 17, 2023 12:16 AM
boostedion
18
Apr 12, 2011 05:16 PM
Hybrid96EK
Mar 25, 2010 05:56 AM
jyacoba2009
21
Oct 7, 2009 05:29 PM
NHB
Apr 3, 2007 04:29 AM
