mini me need help
mini me need help
ok so i did a mini me swap. i follow the many write up on here. this is a 00 hatch with the d16y7 with a d16y8 head. Now i got it running but really crappy. im using a p2p ecu. i was wondering if the cam gear on the y7 is different from the y8 cus im using a y8 one an im sure the timing is off. i was getting misfires den i retarded the dizzy all the way now im not getting a cel but it idles really low. any advice or comment is appereicated.
ps im using y7 intake mani for now.
Re: mini me need help
y7 an y8 use the same cam gear.
you may be off by a tooth if it runs that badly.
the y7 intake manifold sucks, get rid of it. also y7 injectors are 190cc instead of 240cc that your p2p ecu thinks it has, so you are probably running lean.
no i am using y8 injectors. i am kinda stump i check the timing like 3 times. every time is like half a tooth or a tooth off...getting soo frustrated. thanks guys for the input...i still need help. with the dizzy all the way retarded i have no cel runs crappy n low idle.
boostedion
18
04-12-2011 05:16 PM
jyacoba2009
21
10-07-2009 05:29 PM
NHB
04-03-2007 04:29 AM
