map sensor
It mostly has to do with the high vacuum area, specifically where the voltage cutoff is. It shouldn't make enough difference to be noticable, but it would be a good idea to check AFR's with a wideband. At most you'd just have to adjust the first two columns for idle.
quickchris
Jul 28, 2006 09:47 AM
Topdawgg
Jul 1, 2006 08:22 AM
