3 bar map sensor connector request!!!!
Old Mar 24, 2004 | 01:02 PM
SleepinTeg's Avatar
Default 3 bar map sensor connector request!!!!
Hi, does anyone know where i can get a 3 bar map sensor connector? Thx Jason
Old Mar 24, 2004 | 01:09 PM
salt's Avatar
Default Re: 3 bar map sensor connector request!!!! (SleepTeg)
Do you mean the pigtail connector ? I went to autozone, or murry's and looked at all of them until I saw one that looked close. I think it was an A/C connector from a GM car. I had to slightly modify it with an exacto knife. It was about $8
Old Mar 24, 2004 | 01:27 PM
b_jamin's Avatar
i think i read something on here about pepboys always having them instock...
Old Mar 24, 2004 | 02:13 PM
SleepinTeg's Avatar
Default Re: 3 bar map sensor connector request!!!! (b_jamin)
So, do u know what the name is?
Old Mar 24, 2004 | 02:20 PM
quikB18B's Avatar
I got mine at pepboys for like $10
Hondatas website has a part #, however the one I got is the one hondata described however it was a slightly different part # then they had posted. It was like a fan pressure switch or a clutch switch, ahhh i can't remember. I also had to use an exacto knife to cut slits in the connector to allow it to slide in to make contact but it's easy. I think there is a connector that is a direct plug in, also from a Gm but I dont know the exact part #. Go to hondatas website and get the part #, and call pepboys, and describe to them what you need and they should be able to get the pigtail for you.
Modified by quikB18B at 3:56 PM 3/24/2004
Old Mar 24, 2004 | 02:22 PM
b_jamin's Avatar
quikb18b knows...and i think that might have been where i saw it also
Old Mar 24, 2004 | 06:43 PM
SleepinTeg's Avatar
Default Re: 3 bar map sensor connector request!!!! (quikB18B)
I went to pepboys and they said they dont have on stock. Could u tell me what GM vehicle has this sensor? Thx
Old Apr 4, 2004 | 12:35 PM
LBR92DA-T's Avatar
12085502 here is the part number from gmpartsdirect.com
Old Apr 4, 2004 | 12:36 PM
LBR92DA-T's Avatar
also click here for other gm pn's http://forum.aempower.com/bbs/viewtopic.php?t=920
Old Apr 12, 2004 | 10:10 PM
Turbo'dMex-A-Keen's Avatar
Default Re: (LBR92DA-T)
The Chevy and GM diesel trucks have them, go to a junk yard and find a diesel chevy or gmc and the sensor and connector should be on the firewall. Or i can go to the local JY and get a good load of sensors and connectors for everyone...would anyone be interested? Let me know
TM
Old Apr 12, 2004 | 10:39 PM
Hoosier Daddy's Avatar
Default Re: (Turbo'dMex-A-Keen)
http://www.gmpartsdirect.com
GM 3BAR MAP Sensor P/N: 16040749
GM 3BAR Wiring Pigtail P/N: 15305891
Old Apr 13, 2004 | 08:33 AM
Default Re: (Hoosier Daddy)
damn i can get them cheaper than that... oh and theyre not in stock
who wants one?
TM
Old Apr 13, 2004 | 09:13 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo'dMex-A-Keen &raquo;</TD></TR><TR><TD CLASS="quote">damn i can get them cheaper than that... oh and theyre not in stock
who wants one?
TM</TD></TR></TABLE>
I'll be needing one real soon. I have the PFC though, will these still work for me?
Old Apr 13, 2004 | 09:54 AM
Default Re: (4-banging)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging &raquo;</TD></TR><TR><TD CLASS="quote">
I'll be needing one real soon. I have the PFC though, will these still work for me?</TD></TR></TABLE>
What? let me know so i can figure it out
TM
Old Apr 13, 2004 | 10:05 AM
4-banging's Avatar
Apexi Power FC
Old Apr 14, 2004 | 08:56 AM
Ohh i see, wasnt familiar with the abbreviation sorry.
It should work, i think the only thing u have to do is change on the PFC is the Map sensor signals in and out. If u want i can research what all u must do.
TM
Old Apr 14, 2004 | 09:02 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo'dMex-A-Keen &raquo;</TD></TR><TR><TD CLASS="quote">Ohh i see, wasnt familiar with the abbreviation sorry.
TM </TD></TR></TABLE>
If you don't mind...this is going on a b16a2 using the Apexi Power FC
thanks again
Old Apr 14, 2004 | 09:29 AM
CRX T-Si's Avatar
I thought the 3bar map was the same as the ones from the Camaro/LT1 engine.
Old Apr 14, 2004 | 10:02 AM
Bailhatch's Avatar
Default Re: (CRX T-Si)
I just got one at a junkyard. found it on some old grand am. I'm pretty sure you can find them all over any GM cars. It looked like most of the 3 wire plugs are the same. it was 1$
Old Apr 14, 2004 | 12:12 PM
Default Re: (Bailhatch)
Yup what he said.
sihatch19
May 28, 2008 09:56 AM
h22sedan
Dec 3, 2006 07:46 PM
null.
Dec 15, 2005 06:35 PM
Boostless97Lude
Dec 7, 2002 05:26 AM
gs-turbo
Mar 23, 2002 01:08 PM
