2 problems for EK coupe.
Old Nov 12, 2009 | 05:03 PM
jyacoba2009's Avatar
Default 2 problems for EK coupe.
Well I thought this was happening due to my head gasket being blown, but it just got fixed.. and its still happening.
96 Civic DX, Automatic
1) During cold start ups (car being turned off minimum 10-15 minutes) it will have a hard time starting. So, I just turn the key on and off to pump some fuel, and that helps it to start, BUT.. when it does start, it will be shaky and than it slowly dies out, UNLESS.. I put it into gear and than its fine and dandy.
The main relay, fuel pump, and fuel filter are all good. Some things I didn't check yet is the FPR, Fuel Injectors, or Fuel Rail. I can suspect that it might be bad gas, b/c when my mom used my car, she put Rebel gas in it (I always go to Shell or Chevron) and maybe it just ****ed with it, or somethin.
2) Before my car was sent into shop, the acceleration was quick during 1st gear (like from a stop at a red light), but now i have to push the pedal maybe more than half way for it to pick up enough speed, so that i could at least keep up with the traffic.
Could this be somethin with my acceleration cable? or.. is it because im still in the "breaking-in" period since I had my head rebuilt?
-Jovan
Old Nov 12, 2009 | 05:47 PM
Default Re: 2 problems for EK coupe.
ttt
Old Nov 12, 2009 | 11:55 PM
bump
Old Nov 13, 2009 | 12:05 AM
ekb16a's Avatar
kinda same problem i would guess a leak some were chnage sparkplugs see if continues i gonna do that soon
Old Nov 13, 2009 | 12:47 AM
rhdej6's Avatar
just check the rest of the stuff u need to check..injectors, regulator,fuel rail..ect..
prob ur inj. are full of gunk n ****..replace the plugs also. all that will do some good..u should feel the diff..
bout the acceleration prob, its probably due to that issue at start up..double check ur cable though..lol ...
Old Nov 13, 2009 | 04:46 AM
lol i tried checking my cable, but i cant understand what my haynes manual is telling me to do.. "wiggle room" or some ****, lol.. so im not gonna touch the acceleration problem..
im thinking regulator right now.. i'll check it once theres light
Old Nov 13, 2009 | 06:29 AM
TheCivicMafia's Avatar
if your cable is wrong, it should be running below 700 rpms at idle, or stall out, Take throlle cleaner and clean your tps and iacv spots.
If you want to know if your fuel system is working, pull out and injector and have someone turn your car over it should squirt fuel.
Do you have any CEL's on?
Old Nov 13, 2009 | 08:03 AM
fastrxu's Avatar
Are you burning oil
Old Nov 13, 2009 | 08:39 AM
keving85's Avatar
check your cam to crank timing. could be out a tooth ... would explain your long cranking and lack of power
blueBB4lude
Dec 10, 2009 12:00 PM
dsturch1
Oct 15, 2007 10:47 AM
oakpwr
Jan 13, 2007 08:43 AM
bengal
Aug 9, 2006 08:50 AM
prendi
Aug 9, 2005 09:14 AM
