car won't start need help
it was driving fine last night before i parked it..went out today and the car wont start..when i go to start it, it makes a like fast tapping noise. also my 4th fuel injector to the right is leaking gas..any ideas on what's wrong with my Sol?
tapping from inside the vehicle? this sounds like your main fuel relay clicking. Check your grounds i ran into this same problem before. atleast by what it sounds like?
could be the battery jump some wires from a different car and see
i don't think the batttery would cause the trans to shift badly. if the voltage was too low to make the trans shift worse it would have a hard time running and starting like you have already experienced
but you can check your battery voltage your self with a meter and if you need it load tested take to autozone or advanced the will check for free.
gavingt
Jun 22, 2017 09:28 PM
laziebun
Apr 24, 2008 11:10 AM
