d16z6 engine turns over but won't start
I just purchased a 94 civic ex with 133,000 miles on it. I knew when I bought it that it had engine problems, had to take it home on a car dolly. I figured at the most I'd have to replace the engine, but I'm hoping to fix what is wrong with this engine.
The owner of the car said he was driving the car and the oil light came on, he stopped and checked the oil and it was fine. He kept on driving and 10 minutes later the car died on him, this was the last time the car was running.
I pulled the spark plugs and tried to start the engine to see if the spark plugs were firing. The ignition system seems to be fine. I was also curious to see if the timing belt was fine, so I pulled the valve cover. There was a lot of build up on the head, poor maintenance I assume, but the timing belt appeared to be fine. I don't have a fuel pressure gauge at the moment or I'd check that. I'm just wondering what else it could be...
no point in going any further with that big Goose egg on cyl 3.....
pull that motor out, man.
rebuild it with a vitara setup, boost it, tune it.......
GO SINGLE SLAMS!!!
GO SINGLE SLAMS!!!
Well I started to remove the head, removed the exhaust, started unbolting the head. I couldn't get the top timing cover off, got the right bolt off but the left was recessed, maybe they used a non factory bolt. Power steering is really in the way. I had drained the coolant and oil.
Did all this then noticed this:
tikishow
Feb 28, 2007 08:52 AM
jetpilot
Apr 22, 2004 05:44 AM
FuzzyGreen
Jan 8, 2003 07:48 PM
