2 Step Launch Control???
Old Nov 4, 2009 | 02:17 PM
Tong.Y's Avatar
Default 2 Step Launch Control???
Whats is required for my 95 civic d16z6 swap?
what do i need?
how does it work/operate?
Old Nov 4, 2009 | 02:20 PM
93egSLEEPER's Avatar
Default Re: 2 Step Launch Control???
its nice to have if you plan on dragging it at all. basically what it does is set a "rev limiter" when your car is not in motion allowing you to hlod the gas to the floor and not have to try and hold it steady when launching. just dont set it too high or too low or your defeating the purpose. youtube it and you will get a better idea of what is it.
Old Nov 4, 2009 | 02:22 PM
hannslebo's Avatar
if your just looking for the 2step you can get on ebay and order a chipped ecu. it deletes your gov. and rev limit to like 9.2 and your CEL as your shiftlight and of course 2step. I have one and its set at 4900 rpms although i want to change it to like 5100. (B16)
Old Nov 4, 2009 | 02:25 PM
Tong.Y's Avatar
what do i need to get?
Old Nov 4, 2009 | 02:31 PM
jdmEK9FTW's Avatar
get a chipped ecu, and maybe traction bars if your car wheel hops
Old Nov 4, 2009 | 03:10 PM
Tong.Y's Avatar
are chipped ECu's hard to find?
sorry i dont have a clue about chipped ECU
Old Nov 4, 2009 | 03:33 PM
jdmEK9FTW's Avatar
no not really, you can buy a chipped ecu on ebay for like $100 or less, you can have your local speed shop chip and tune your ecu if they know how too or you can also buy like hondata. there not hard to find. just check ebay, craigslist or your local shop
Old Nov 4, 2009 | 03:34 PM
i wouldnt reccomend traction bars on a stock d16, or for a daily driver. its not a necessary part unless you are running high hp and on slicks you still get wheel hop.
Old Nov 4, 2009 | 03:48 PM
jdmEK9FTW's Avatar
i guess your right, i had traction bars on my dd eg but then again it had 350whp
Old Nov 4, 2009 | 04:36 PM
boxeocampeon's Avatar
you need the motor and a car
Old Jul 1, 2010 | 06:06 PM
Coonword's Avatar
im no expert but i would never buy a chipped ecu off ebay let alone use one of their garbage chips ur taking a big chance useing a chip someone made that has no idea your engine set up i would recommend goin to www.xenocron.com and buying a chipped ecu or goto http://phearable.net/ and order a cipping kit it somewhat easy to chip...their chips are custom to your engine set up and they let you choose where u want two step etc.
stiffymeister28
Jun 10, 2011 08:22 AM
1995honda
18
Oct 22, 2009 04:01 PM
SpdKilz23
Sep 28, 2008 08:51 AM
96SOoSaUCCY
May 29, 2008 06:36 AM
accord_si
Sep 11, 2006 01:34 PM
