791 bypass with viper 5900 help
Old Oct 2, 2009 | 06:41 PM
laziebun's Avatar
Default 791 bypass with viper 5900 help
what the hell do i hook up to what on the 5900?? its for a 2003 honda odyssey. Can i also cut the key and just leave the black part of the key in the 791 only??
Old Oct 3, 2009 | 05:41 AM
laziebun's Avatar
Default Re: 791 bypass with viper 5900 help
do i just connect that blue wire from the 791 to the blue (-) status output wire on the relay satellite on the viper 5900???
Old Oct 3, 2009 | 07:08 AM
jdmb18hatch's Avatar
the blue wire on the 5 pin harness.
Old Oct 3, 2009 | 12:04 PM
laziebun's Avatar
you mean 4 pin harness on the relay satellite box
Old Oct 3, 2009 | 03:18 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
No do not use that one. Use the blue/white on the remote start harness. The one that controls the rear defoggers. Works better.
Old Oct 3, 2009 | 03:25 PM
laziebun's Avatar
i was going to hook up the rear defogger also. Why is that one better then the other??
Old Oct 3, 2009 | 03:45 PM
laziebun's Avatar
if i hook it up to the defogger blue/white wire would i need a relay since it only puts out 200mA unlike the one on the relay satellite where it isnt 200mA
Old Oct 3, 2009 | 05:43 PM
Its easier and cleaner to use the way i posted above
Old Oct 3, 2009 | 06:55 PM
laziebun's Avatar
well i cant use that if im using the defogger right?
Old Oct 4, 2009 | 12:23 AM
Yes because if you are using the rear defogger you need to use a relay to switch the ground output to a high current ground. SO there is engough ground to trigger both. Out in calie we dont need the rear defogger. Plus I dont like the wear and tear on it. Running at all the time you remote start the car. Most of the time you will never need it.
Old Oct 4, 2009 | 04:47 AM
laziebun's Avatar
so if its saying it puts out 200mA (-) does that mean it grounds that wire when activated? Which would mean i put that wire (defogger) to number 85 of the relay coil and on number 86 i supply it with voltage, so that the coil will activate when triggered? and pull current from number 30 to number 87???? and thanks for your help WRX
Old Oct 4, 2009 | 04:48 AM
laziebun's Avatar
oh and there's a way on the controller to turn off the defogger when not needed, so im not to worried about wear and tear. i dont want to use both options on that one wire. I want to be able to turn off the defogger on warm days.
Old Oct 4, 2009 | 11:06 AM
On ther blue wire to runn the deffogers, blue/white goes to 85 to the relay, 86 to 12 volts. 30 to ground and 87 to the deffogers neg input.
For the remote start use the blue wire off the remote start pack. Make sure you use a diode or the unit will stay on.
Old Oct 4, 2009 | 11:10 AM
laziebun's Avatar
i have an issuse i can not fine the 6 pin plug for the lock and unlock. It says it on the drive side kick panel. Can anyone help
Old Oct 4, 2009 | 12:54 PM
Don't you have a multi meter?
Old Oct 4, 2009 | 01:09 PM
laziebun's Avatar
yeah but still cant seem to find it. the wire should read 12v correct??
Old Oct 4, 2009 | 01:19 PM
They are neg triggers to control the door locks. It might read 12 volts at rest. Thats residue voltage from the relay box. Text each wire till you find the one that shows ground when you lock the door from the switch.
Old Oct 9, 2009 | 02:57 AM
laziebun's Avatar
Why would i need a diode? The defogger would only stay on when the remote start is active or am i missing something?
RGoose18
Audio / Security / Video
Sep 8, 2009 04:36 AM
TheCivicMafia
Sep 1, 2009 07:34 PM
DBAl
Jun 1, 2009 05:50 AM
nocturnal EG
16
Nov 3, 2006 08:04 AM
Full Race A6
Apr 4, 2004 07:12 AM
