Fuel pump setup
I didnt know you could mount it that way? and i couldnt figure out were To mount it besides a slip on mount with a brace.. so i mounted this way?
any input pros and cons?
Yeah I run the weldon 2025. These pump are sucker stlye pumps, unlike the aeromotive pums they work upside down or up right. they dont rely on gravity for the fuel ( thats why i bought mine). Theres really no cons the way you have it except it might get caught on somthing if its to low.
whoa holy non ground clearance.......
same pump, different filters now but same mounting position. no issues. fits under stock bumper:
with the new pre and post filters:
i havent used the sx, but as for customer service, i had an issue with the pump, and when i called weldon to fix, jim craig gave me his personal cell #, told me who to go to to get parts, gave me wholesale on the parts, and when they came in, walked me through fixing the pump.
their pumps are bad ***, their customer service is top notch.
no i actually didnt vent the tank properly, and the pump was caving the tank in. and broke the drive coupler. or the lovejoy. it is a coupler between the pump motor and pump drive. it is a fuse. and is designed to do that. call weldon, ask for jim craig. see what he says.
from weldons site: this is the db2015a. the 2025 and 2035 flow more and make moew power.
Maximum HP:
1000 hp @ 14V EFI (500 hp on Methanol)
1050 hp @14V carb (525 hp on Methanol) GPH/PSI Range:
85-115 GPH / 0-160 PSI
i dont think a 100 base is out of the question.
i personally dont like running 2 pumps. but people use it and have made it work.
Maximum HP:
We got hooked up with SX Performance fuel systems and have had awesome results since the changover. Not that Walbro was bad, but now we have some headroom for future development where we were near the end of the capacity of the old pump.
http://www.sx-performance.com/
The fuel cell is right behind the passenger headlight and the fuel rail is centered just behind the radiator so everything is close and easy to take care of.
slwazgsr
Oct 12, 2002 07:37 AM
